Catalytic Converter Replacement? CA?
Old Feb 11, 2010 | 04:45 PM
ThirdGenFire93's Avatar
Car: 1987 Firebird Trans Am
Engine: 305 TPI (68,XXX MILES!)
So these will pass all smog standards here in CA?
If so, will these give me a better sound/more performance? :O
http://www.autoanything.com/exhausts...A3993A0A0.aspx
ALSO. It asks me if I have a code "F" Engine or if I have a code "H" Engine. I have a 5.0 TPI. What does F or H mean? Im assuming one is for TPI and one is for TBI. HELP ME! LOL.
Old Feb 12, 2010 | 09:54 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Catalytic Converter Replacement? CA?
Cali has gotten very strict on their cats recently and you'll want to make sure whatever you get has the proper part number/coding stamped on the cat or else you may be dumping a lot of money for a part that does not pass your visual inspection.
as for engine code, its referring to the 8th VIN digit.
Old Feb 12, 2010 | 02:47 PM
Okay so the code is F, awesome. Thanks! But it says that it will pass all Cali's expectations for smog, can I trust that?
Old Feb 18, 2010 | 03:16 AM
HAS anybody in CA ever replaced their catalytic converter before?? I'm just curious, I don't want to buy this and then fail the inspection.. IT says its all CA legal, it meets CA standards etc.. What do you guys think? :O
Old Feb 18, 2010 | 11:38 PM
mikespeed's Avatar
Car: 87 IROC
Not on my camaro, but I would bet that the shop you take your car to for a new cat is going to get that cat from somewhere like CSK or Napa or something like that. I would just call a few parts stores and ask them for a Ca. legal universal, or weld in cat. a weld in will require welding (duh) but its still a lot less $$ than a direct fit.
If I had to guess I'd say you could get a legal weld in cat for somewhere around $170 and maybe $100 to have it installed.
Old Feb 22, 2010 | 06:07 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
your VIN will be at the corner of your driver side dash near the bottom of the windshield. You can also find it on a lot of the body panels (I've seen em on the hood, hatch, doors, etc) but if anything's ever been changed, you may get the wrong number. The dash one is the most reliable source.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
