CAT QUESTION ?????
Old Mar 10, 2010 | 03:31 PM
coolhandluke937's Avatar
Car: 1987 Blue IROC Z
CAT QUESTION ?????
I BOUGHT AN 87 IROC THAT HAD THE 305 PULLED AND A 350 WITH HEADERS PUT IN IT'S PLACE. WHEN THE GUY PUT IN THE LARGER ENGINE HE PULLED THE EMISSION COMPONENTS OUT ALONG WITH THE CAT....... SURE THE CAR SOUNDS MEAN WITH THE PIPE RUNNING BACK TO A CHEAP DUAL OUT MUFFLER BUT THE EXHAUST FUMES ARE HORRID..... CAN I PUT A HIGH FLOW CAT BACK WHERE IT SHOULD BE WITHOUT HAVING PROBLEMS ? OR WHEN I DO THAT AM I GOING TO HAVE FLOW ISSUES AND OR COMPUTER CODE PROBLEMS ?
Old Mar 10, 2010 | 10:46 PM
DemonYusuke's Avatar
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
Re: CAT QUESTION ?????
you will be fine if you get a high flow cat and put it where it should be you will have no problems, if your not throwing codes for having it removed you wont for putting it back on. High flow cats are designed to be less restrictive, it will flow differently but it shouldnt effect your engine or performance enough to even notice, the sound will be just about the only thing to change and the smell of course.
Old Mar 11, 2010 | 12:17 PM
EXCELLENT, THANK YOU !!!!!
chazman
Aug 28, 2018 03:25 PM
Out-Cast
Aug 22, 2015 07:49 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
