Sinister 4"
Old Mar 22, 2010 | 04:11 AM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
Transmission: 700R4/ Edge 3400
Axle/Gears: 10 bolt/ Richmond 3.73
Sinister 4"
http://www.hawksthirdgenparts.com/ha...stsystem4.aspx
Has anybody seen this kit yet or used it? Seems like the Mufflex minus the muffler. Uses the 4th gen 3" y-pipe outlet at this catbacks inlet but it can be cut off. Just add muffler of your choice and your ready to go.
Old Mar 22, 2010 | 01:21 PM
Goosehead's Avatar
Re: Sinister 4"
If it's just the parts shown on the pic. then $399,- is WÁY too much!
I built an entirely new 3 inch exhaust , from between de headers and exhaust tip for just €250,- !!!
Stainless steel that is
Old Mar 22, 2010 | 03:00 PM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
Re: Sinister 4"
Yes but that is 3" though. Nobody but mufflex ofers a 4" kit with a muffler for less than $550-ish.
Old Mar 22, 2010 | 06:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Sinister 4"
that not a bad deal, grab a good 4" muffler, about a 150bux, and its still cheaper than mufflex
Old Mar 23, 2010 | 12:33 AM
EvilCartman's Avatar
Car: '82 Z28
Re: Sinister 4"
You need to look at the prices for 4 inch stuff. Just parts alone for mine it's going to be at least $350.
Old Mar 24, 2010 | 04:22 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Re: Sinister 4"
Yeah, thats a pretty good price. Cheaper than the mufflex stuff now and even if you wanted to make it yourself, I doubt your going to do much better cost wise. I mean your getting a 4" system, mandrel bent and ready to install.
Old Mar 24, 2010 | 05:36 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Sinister 4"
How do they get a 4 inch pipe above teh panhard bar mount? I've got a 3.5 inch pipe there and it still needed to be BFH'd to fit.
newexh2.jpg?t=1269470196
Old Mar 24, 2010 | 06:32 PM
6262TransAM's Avatar
Re: Sinister 4"
I really like the 4" kit I purchased from Mufflex.
Old Mar 25, 2010 | 02:01 AM
Car: 1992 Camaro RS
Re: Sinister 4"
Can you get a pic of it going over the panhard bar mount? Like I said, there's just no room there for a 4 inch pipe... Im curious to see what they did.
Old Mar 25, 2010 | 02:11 AM
Re: Sinister 4"
I will post pix soon of your request. Cat back fits well. Tight all over but excellent design! When I first received the kit I said "OM Goodness" nooo way that is going to fit.lol I have about an 8th of a inch over the axle. I do have the TTA however.
Old Apr 21, 2010 | 10:15 PM
QUICK305's Avatar
Re: Sinister 4"
Looks like the system comes with a bullet muffler.
Anyone here used this kit?
Old Apr 22, 2010 | 01:56 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Sinister 4"
doesnt look like it comes with any muffler
Old Jun 17, 2010 | 06:38 PM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
Re: Sinister 4"
it doesn't, has anyone ordered this exhaust? I wonder if it is too loud. I'm going to order one tonight and stuck between the sinister and the dual outlet 4" mufflex/spintech exhaust
Old Jun 17, 2010 | 09:28 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: Sinister 4"
Judging by the pic's it looks exactly like my mufflex 4" kit minus the muffler.
Old Jun 18, 2010 | 12:01 AM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
Re: Sinister 4"
im going to get the sinister and it it is too loud for my liking ill just get a 4 in/4 out ss spintech muffler...im kinda use to the left side exit with my factory installed slp setup
Old Jun 18, 2010 | 08:51 AM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
Re: Sinister 4"
Well since you already have an aftermarket lower panhard bar, that upper stamped piece is a "look left, throw right" item. There would be your extra clearance. You have to remove that to get the mufflex to fit too.
Old Jun 20, 2010 | 10:29 PM
Tony89GTA's Avatar
Car: 89 GTA
Re: Sinister 4"
The mufflex 4" system will fit with that bar in place.
Old Sep 13, 2010 | 12:56 PM
sleeper84's Avatar
Car: 1989 RS
Engine: LO3 5.0L
Axle/Gears: 10b 2.73
Re: Sinister 4"
Anyone ever come up with a picture of this crossing the panhard bar support brace? I'm wanting to put the Sinister 4" system on my 84.
Old Sep 13, 2010 | 01:33 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Sinister 4"
I've built a 4" for my car and you can get 4" to clear the panhard bar brace. I've since then took that brace out and noticed no problems with the car.
4" Ultraflo by dynomax I have used and also the Dynatech Split flo / borla XR1 clone muffler. Both are very loud on a 11 to 1 compression 11 second 383 motor I had but quiet on my 401 turbo motor. Turbos tame the exhaust down alot.
Not a bad price for a 4" kit without a muffler if it fits nicely.
Old Sep 13, 2010 | 01:36 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: Sinister 4"
i just dont see $400 worth of parts...
Old Sep 13, 2010 | 01:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Sinister 4"
It is very pricey for that amount, unless its stainless then its abit more worth it but still kinda pricey for what you get. Still cheaper than Mufflex stuff with a muffler.
Old Sep 14, 2010 | 12:25 PM
sleeper84's Avatar
Car: 1989 RS
Engine: LO3 5.0L
Re: Sinister 4"
Considering it's mandrel bent 4" exhaust and no one around me does mandrel bent, it's worth it to me.
Old Sep 14, 2010 | 02:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Sinister 4"
You can buy the bends from Summit or other places and fab your own system. You probably wont have anywhere near that much in the piping but factor in fabrication time and weld time and it all starts to add up. I think I made my 4" "catback" which was from y pipe back for less than 200 bucks in parts. Only need like 5 J bends and you should have enough to complete it all and J bends are usually 30 or less dollars per bend depending. I know I can get good bends out of stainless for around 25-30 a bend from a local shop.
If you cant fab it yourself, and its really not all that difficult, then 400 for that kit isnt horrible. Pricey yes, but unbearable no.
Old Sep 14, 2010 | 05:53 PM
sleeper84's Avatar
Car: 1989 RS
Engine: LO3 5.0L
Re: Sinister 4"
I just don't have the time to do it myself. I work out of town so it's worth the $400 to me to save the time I'm at home. I do need a 2.5" dual inlet 4" single outlet T if anyone knows where to get one. I don't need stainless, just a decent T.
Old Sep 16, 2010 | 09:46 PM
Tony89GTA's Avatar
Car: 89 GTA
Re: Sinister 4"
Pic of my mufflex system but pretty sure it's the same pieces.
Old Sep 16, 2010 | 10:09 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: Sinister 4"
Nice!
I got the 4" sinister exhaust and I bought a 4" flomaster from Summit for $130.
I'll tell you in a month how it fits
Old Sep 16, 2010 | 10:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Sinister 4"
quick pic of my 4" over axle and upper panhard bar support thing. Thats a flowmaster y 4" to dual 3". I flipped it and used it to make a splitter over the axle to maintain dual outlets since I didnt want to use a spintech muffler. So there is plenty of room to get 4" over
Old Sep 17, 2010 | 04:32 AM
sleeper84's Avatar
Car: 1989 RS
Engine: LO3 5.0L
Re: Sinister 4"
Thanks for the pictures guys. I'm definately going to go with a 4" system fed from two 3" pipes from my collectors.
Old Sep 25, 2010 | 09:57 AM
fenton06's Avatar
Re: Sinister 4"
What is everyone using for a Y pipe with these exhausts?
Old Sep 25, 2010 | 05:59 PM
Tony89GTA's Avatar
Car: 89 GTA
Re: Sinister 4"
Custom of course, I used a bunch of flowmaster S-bends and dual 3" to a 4" Y collector.
Old Sep 25, 2010 | 08:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Sinister 4"
Mufflex sells a 3 to 4" ypipe for their catback system which also should fit this sinister one.
Old Oct 14, 2010 | 01:48 AM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
Re: Sinister 4"
would like to hear the mufflex or sinister exhaust if you could post some vids.
Old Jun 25, 2011 | 03:15 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Re: Sinister 4"
Here are pics from my set-up
I got the sinister kit with a flowmaster from summit (it was a little cheaper this way)
I had to buy two 45 degree 4" pipes to complete it.
I have a custom 3" y-pipe to a single 4" to the back with single outlet
https://www.thirdgen.org/forums/atta...1&d=1309032866
https://www.thirdgen.org/forums/atta...1&d=1309032930
Attached Thumbnails Sinister 4&quot;-exh-2.jpg   Sinister 4&quot;-exh-3.jpg   Sinister 4&quot;-exh-4.jpg
Old Jun 25, 2011 | 03:16 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Re: Sinister 4"
https://www.thirdgen.org/forums/atta...1&d=1309033015
Old Jun 26, 2011 | 12:39 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Sinister 4"
looks good!
Old Jun 26, 2011 | 02:07 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Sinister 4"
My 4" fit fine over the panhard brace. I went the cheap route. 4" piping, bunch of 90* bends, hangers, 4" clamps, used muffler, and a turn down that came with muffler. I think I figured up I have $180 in the everything after the Mufflex y-pipe.
Old Jun 17, 2012 | 07:09 PM
nickynick17's Avatar
Car: 1989 Firebird Formula 350
Engine: 350 TPI L98
Axle/Gears: 3.91
Re: Sinister 4"
I read that this exhaust isnt meant to be used with less than 400 HP is this true will you use a lot of back pressure with this system on a stock L98?
Old Jun 17, 2012 | 08:44 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Sinister 4"
You want to lose ALL your back pressure... Unlesssssss you have a 2 stroke motor.
Old Jun 17, 2012 | 09:58 PM
Engine: 350 TPI L98
Axle/Gears: 3.91
Re: Sinister 4"
ok but im wondering if having this bigger pipe will cause the car to be more sluggish when give it gas from a stop due to the stock power of the L98, i noticed it doesnt feel like my car has torque when i have my cutout open thats located right after the y-pipe and before the cat
Old Jun 17, 2012 | 10:01 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Sinister 4"
thats just an illusion, louder cars seem slower when you in them. exhaust backpressure is never a good thing
Old Jun 23, 2012 | 05:53 PM
5spd-iroc's Avatar
Car: '85 iroc-'13 powerstroke H&S tuned
Engine: 406 sbc full roller
Transmission: t5 soon to be t56
Axle/Gears: stock
Re: Sinister 4"
im ordering this exhaust even tho i just finished my exhaust
<object width="420" height="315"><param name="movie" value="https://www.youtube.com/v/UPz1Gcklbs...</param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="https://www.youtube.com/v/UPz1Gcklbs...3&amp;hl=en_US" type="application/x-shockwave-flash" width="420" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
Old Jun 23, 2012 | 05:56 PM
  #42
5spd-iroc's Avatar
Axle/Gears: stock
Re: Sinister 4"
i dont know how to embed the video damn
5spd-iroc
Apr 9, 2013 07:16 PM
Sinister87s
Exterior Parts for Sale
Jun 23, 2012 12:06 PM
Sinister87s
Mar 28, 2011 02:31 PM
Sinister87s
20
Feb 26, 2009 06:55 PM
LMSkyliner
May 16, 2008 06:50 AM
