Cat' verter help milage?
Old Apr 4, 2010 | 10:37 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Ok, here's an exhaust 101 Q--
Other than emissions, what purpose does the cat serve? Do cats affect gas milage?
All I know is they " convert " CO2 to less harmful amounts, & get hot.
We have no ECM, so there's no O2 sensor. Til I can afford a good cat, we have a " temporary " pipe in it's place.
Thanks for any education!!
Old Apr 5, 2010 | 08:16 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Cat' verter help milage?
Its emmisions equipment. Thats it. I have none on my Camaro.
Old Apr 5, 2010 | 09:08 AM
Car: '87 Camaro
Thanks for the info!!
Old Apr 5, 2010 | 09:39 AM
Stephen's Avatar
Car: 87 GTA
With an ECM, adjustments can be made from moment to moment which MIGHT help with mpg.
Without that ECM tuning going on, I don't think it would have much, if any, effect on mpg. Unless it was a clogged up/bad flowing one. Then that would be more of having to depress the gas pedal further to create more power, just to get a car to move. But that would be the case even with ECM tuning going on so.....
Old Apr 5, 2010 | 04:25 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
an engine needs to inhale & exhale just as you & i do . if cat. is old it may well be clogged . try to inhale through your nose & exhale through your mouth covered with a paper towel . you can do it but your not going be doing anything to your full potential . there are many " hi-flow " cats. out there , and many of us ( me ) have eliminated our cats. yes a clogged cat. can affect mileage . whatever you decide , good luck .
Old Apr 5, 2010 | 05:37 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Actually catalytic converters convert carbon monoxide (CO) into carbon dioxide (CO2) among other things.
http://auto.howstuffworks.com/catalytic-converter.htm
Cats tend to get rid of the rattling sound that exhausts have when you rev them up. Also help act as a muffler to a certain extent.
Old Apr 6, 2010 | 09:07 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
It doesn't convert c02, when it reaches 900*F it converts HC's and CO to CO2 and H2O, and reduction converters also convert NOx..
Perform a vacuum test to determine if its plugged.
Old Apr 9, 2010 | 11:14 PM
Car: '87 Camaro
Thanks for the education!
So since we have no ECM, the temp pipe will have to do for now.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
