H pipe on a third gen????
Old Apr 19, 2010 | 09:19 AM
Bowtiebruiser's Avatar
Car: 1982 Camaro Z-28
Engine: 350 4bbl
Transmission: Borg Warner Super T-10
Axle/Gears: Richmond 10 bolt 4:10 Posi
I was just reading an article in either GM High Tech or Camaro Performers on this maroon IROC that had long tube headers and an H pipe. I was wondering which H pipe that guy used?
Old Apr 19, 2010 | 02:54 PM
Pocket's Avatar
Car: 91 Trans Am
Re: H pipe on a third gen????
Most likely custom. 3rd gens are very tight down low and classic routing from off-the-shelf parts rarely fits and when it does it drags on everything
Old Apr 19, 2010 | 03:46 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Just wondering how a H-pipe would benefit a 3rd gen if you are running a Y-pipe?
Old Apr 19, 2010 | 04:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Doesn't.
Old Apr 19, 2010 | 07:16 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
An H-pipe or a X-pipe is for true dual exhaust. A Y-pipe is for running a single pipe back. You can run one or the other, not both.
Old Apr 19, 2010 | 08:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you could run a y-pipe after the h-pipe to convert back to a single
or a y-pipe to a h-pipe and back to a y-pipe so you can say you have a h-pipe
Old Apr 19, 2010 | 08:34 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Old Apr 19, 2010 | 08:58 PM
built91Z28's Avatar
But if your going through all that trouble you might as well throw an X-pipe in there somewhere
Old Apr 19, 2010 | 09:08 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
i ran an x pipe when i fabbed up my dual exhaust years ago.....there is room for one......
Old Apr 20, 2010 | 07:55 AM
Engine: 350 4bbl
Well fine....I'm gonna run a y pipe into an H pipe then an X pipe to a Y pipeand then uuuuuuh...uuuuuuh...YEAH WHAT HE SAID
Old Apr 20, 2010 | 03:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
thats a great idea, then toss 2 cutouts in there too
Old Apr 20, 2010 | 03:15 PM
five7kid's Avatar
Every "test" I've seen with an "H" or "X" pipe involved long tubes and full dual exhaust.
An "H" or "X" pipe allows both banks to benefit from both halves of a dual exhaust system. Obviously, if your exhaust otherwise merges into one, it's worthless.
A cut-out is an admission that you chose your muffler based on some criteria other than flow capacity.
Old Apr 20, 2010 | 08:02 PM
pwdbychevy's Avatar
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
There is room for an x-pipe. Here's my homemade true dual
Old Apr 21, 2010 | 12:24 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
mig or tig? wondering, im guess Mig? i picked up a mig, im going to try this x pipe soon. Nascar status
Old Apr 21, 2010 | 02:29 AM
Engine: 350 4bbl
Wow I bet that sounds awsome
Old Apr 21, 2010 | 03:20 AM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
you got a pic of the over axle routing? Looks like a very clean install
Old Apr 21, 2010 | 04:17 AM
bondue's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 305 V8 TPI
yeah i would love an over axle pic i was wanting to run true duels on my third gen and was trying to figure a good route, from what i've seen here that would work awesome and might i ask what size pipe you used?
Old Apr 21, 2010 | 05:08 AM
pwdbychevy's Avatar
Don't mean to hijack the thread but here's a few shots of over the axle routing. I used 2.5" tubing and a mig welder (Lincoln Electric Pro-Mig 140). There is more pictures of the install at this thread https://www.thirdgen.org/forums/exha...-own-true.html There is also video of what it sounds like at my cardomain.
Old Apr 21, 2010 | 04:46 PM
bondue's Avatar
Engine: 305 V8 TPI
thanks for the pics i hope you dont mind me hijacking your design
Old Apr 21, 2010 | 06:55 PM
pwdbychevy's Avatar
I don't mind but be patient when building it. Get yourself a bunch of 90deg and 45deg bends and about 13ft of straight pipe. I bought out all the 2.5" straight pipe I could find at my local auto parts stores.
Old Apr 21, 2010 | 07:12 PM
White92RSVert's Avatar
I don't want to let the cat out of the bag but pwdbychevy is going to fab one of these for my car Just waiting on more pipe to come in... j/k As I said before... this is awesome work!!!
Old Apr 21, 2010 | 08:25 PM
pwdbychevy's Avatar
LOL! Thanks for the compliment and the heads up
Old Apr 21, 2010 | 08:32 PM
sparkplug619's Avatar
Car: 1990 RS Camaro
Engine: 305 TBI
Transmission: T-5 stick
Thats sexy, looks like a tight but clean fit. Was it a hassle? or simple?
Old Apr 21, 2010 | 09:14 PM
pwdbychevy's Avatar
It was somewhat of a hassle when I started it but got easier as I went along. The hardest part was routing it over the axle.
Old Apr 21, 2010 | 09:17 PM
Car: 1990 RS Camaro
Engine: 305 TBI
From the pics it definitely looked like a PITA to get it around the axle
I really have to say man it looks great, does it sound good?
Old Apr 22, 2010 | 05:11 AM
pwdbychevy's Avatar
It sounds mean as hell. Very deep tone. There's a video at my cardomain.
Old Apr 22, 2010 | 05:18 AM
Twin_Turbo's Avatar
Not exactly a H pipe or X pipe but similar. It's a 3" -> 2.75" from the flange. Going to eb 2x 2.75" down stream also. I may do a side exit/boom tube but not 100% sure yet. I did a test fit and 2x2.75" will fit over my Fays2 rear.....it's a tight squeeze but doable.
Old Apr 22, 2010 | 05:37 AM
resinlake's Avatar
Car: 2011 6.2 Silverado, 88/85 camaro
are you missing some hardware on the pipes or how do they bolt to the headers?
Old Apr 22, 2010 | 05:48 AM
Twin_Turbo's Avatar
V band clamps
Old Apr 22, 2010 | 02:07 PM
resinlake's Avatar
That is sweeet. I also like how you did the Ovalized pipe, very nice. Now I know what to do with some left over stock and pipe. Thanks
Old Jun 24, 2020 | 04:08 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Attachment 414605
Attachment 414606
2 - 2.5" Flowmaster Super 10's?
Old Jun 24, 2020 | 09:44 AM
WTR388's Avatar
Car: 87 Trans Am
I have "total flow" mufflers, cheaper replica of super 10s... I love the sound (long tubes, duals, h-pipe, ls1 with 228/232 cam)
sweet_87_iroc
Sep 25, 2015 10:01 PM
hectre13
Sep 8, 2015 03:38 PM
Warlocksirix
Sep 3, 2015 12:26 PM
transaero
Aug 31, 2015 01:14 AM
FreeSpirit
Aug 29, 2015 05:47 PM
