gutted cat question
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
gutted cat question
is there any way to tell if your cats are gutted without actually removing the whole exhaust? I think mine have been by the smell but the exhaust is welded from headers to tailpipes and i don't have the money to cut it open then weld it back together
Car: 87 GTA
Re: gutted cat question
Nope. Hafta look inside to see, unless you can run a LOOOOOOONG snake up through the exhaust & see if there is any obstruction. No obstruction = gutted cat IF you can be certain the snake is all the way up there & not just caught on a seam weld or in the muffler itself.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
could always tap on it with a small hammer, if it sounds solid, its intact, if it sound hollow, well, you know
Yeah the sound is usually a dead giveaway most times. Mine would make popping noises when you revved it up with a gutted cat. I shoved a straight piece of pipe through the middle and had it welded. Made the popping noise go away, and it sounded much less "ghetto", but it's still a lot louder than a cat that's intact. Thread
ambainb
Apr 25, 2016 09:21 PM
