Headers for 84 camaro
Old May 5, 2010 | 09:09 PM
Jamesonpf5379's Avatar
Car: 1984 Camaro ZF
Engine: 383 stroker
I have a 84 camaro i'm dropping a 383 stroker motor into, i don't have to go through emissions any more I was wondering if anyone can recomend what kind of headers would work nicely for that
Old May 12, 2010 | 04:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Depends upon the 383, and what you'll be doing with the car. Best power with a healthy 383, probably Hooker 2210 long tubes. Best ground clearance and good performance with a mild 383, Hooker 2055 shorties & y-pipe. Best combo of performance and ground clearance, PM TGO member Dyno Don about the headers he makes.
Old May 12, 2010 | 07:51 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Re: Headers for 84 camaro
I see you live in CT. Do they use salt on the roads in the winter? If so go with SLP stainless steel 1 3/4" or 1 5/8" headers. They are more $$$ but if you plan on keeping your car you won't regret it.
Auggie
Old May 16, 2010 | 08:28 PM
Car: 1984 Camaro ZF
Engine: 383 stroker
Where do you think I can get them for a good price?
Old May 19, 2010 | 11:03 AM
five7kid's Avatar
SLP no longer offers their headers.
Ceramic coating is better than stainless because it offers both corrosion protection and heat transfer resistance. If you're doing a high temp application like turbo charging, ceramic coat stainless headers.
What do you consider a "good" price? No matter what, you're going to spend some serious coin to put good exhaust on a 3rd gen. If you're spending the money to put a 383 in the car, it doesn't make any sense to cut corners on the exhaust.
You'll get the best price for the Hookers from Summit or Jegs.
Dyno Don will tell you the price for his headers when you PM him.
Old May 19, 2010 | 11:06 AM
Twin_Turbo's Avatar
Wrapped stainless headers work a lot better than coated headers. The engine bay stays much cooler w/ wrapped headers than w/ coated ones.
Old May 19, 2010 | 11:16 AM
Auggie's Avatar
Yah, we had ceramic coated Expansion Chambers on our modified Sno-X sleds and they had spotty rust after only one season. They looked bad but worked good.
Auggie
evilstuie
Feb 28, 2016 03:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
InfinityShade
Aug 22, 2015 08:00 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
