Exhaust pipe sagging
Old May 6, 2010 | 08:55 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
I need help finding the rubber-like strap that the exhaust pipes hang from near the tips. I do not know what they are called, there is one for each side (with dual exhaust) and without them the pipes sag real low
Old May 6, 2010 | 09:03 PM
JDon's Avatar
Re: Exhaust pipe sagging
i think it's called a boot. and as far as where to get them a junk yard maybe the only place. not sure of to many stores that would sell something like that.
Old May 7, 2010 | 04:46 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Try the autoparts stores. I managed to buy the rear mount your referring to from advance autoparts. It sort of looks like a rubber strap that bolts to the rear subframe rail and to a mounting tab on the exhaust pipe.
Old May 7, 2010 | 10:21 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Most parts should have what you're looking for. It looks basically like an exhaust clamp with a 4-6" rubber strip attached. I need to pick up a couple for my tailpipes as well as they are doing the same thing.
bamaboy0323
Sep 12, 2015 07:14 PM
iroczz89
Sep 12, 2015 04:55 PM
Camaro_383
Sep 11, 2015 11:28 PM
89fast5oh
Sep 8, 2015 09:55 AM
