headman headers?
Old Jun 3, 2010 | 12:13 AM
Dany89's Avatar
headman headers?
What you guys think about headman headers??? part 68471. Good or bad?
Old Jun 3, 2010 | 12:29 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: headman headers?
Best bang for the buck headers out there, I prefer them over hookers and they don't even compare to edelbrocks restrictive collectors. For the money, they can't be beat. I only wish they made a 3" ypipe instead of 2.5", but I plan on fixing that up. The 68471's gave me a 20 rwhp boost on my stock 350 TPI. 2.5" exhaust was my only other mod. Just make sure you get all 90' plug wires and heat sleeves for them, or you'll roast em.
Will
Old Jun 3, 2010 | 01:11 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Great headers, I love them... pretty easy to install and as mentioned you need different wires but I also recall needing to use shorty plugs as well.
Old Jun 3, 2010 | 01:43 PM
Dany89's Avatar
which plugs did you guys use???
Old Jun 14, 2010 | 09:43 PM
norcalz28's Avatar
I got away with stock spec plugs from champion, but I have angle plug heads, you may need shorties with straight plugs
Old Jun 15, 2010 | 12:40 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
great set of headers. i picked up almost half a second on my 305. and yes with stock heads you will need shorty plugs and 90 degree wires.
Old Jun 16, 2010 | 08:18 AM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: 700-R4
Axle/Gears: 4.10
Great headers, easy to install, and cheap compared to the Hookers. Require slight modification to clear the drivers side a-arm. Little tap with a hammer. Nothing serious. May want to invest in a starter heat shield. It gets a little hot with the long tubes.
Old Jun 16, 2010 | 08:28 AM
Twin_Turbo's Avatar
Will
I have them also, a 3" pipe will not fit w/ the stock oil pan and stock crossmember. I built a custom pipe that starts as 3" and necks down to 2.75" and it's a very tight fit:
On stock heads they fit fine with normal plugs & 90 deg. boots
Old Jun 16, 2010 | 08:46 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i run the HTC coated headers, i like them, i'm running world product s/r torquer heads with ac delco straight plugs, no clearance issues, had to use 90 degree boots.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
