Pictures of your Side dumped exhaust
Old Jun 14, 2010 | 04:53 PM
nicc84camaro's Avatar
Car: 1984 camaro 5.0 305 (stock for NOW)
Engine: 5.0 sbc 305.. soon to be a 5.7 350
Transmission: stock automatic with shift kit
Axle/Gears: stock 3:22 i think?????? =S
I want to see pictures of your camaro's side exhaust. Whether it be in front of the rear tire of running full side exhaust.
Old Jun 14, 2010 | 05:39 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Pictures of your Side dumped exhaust
https://www.thirdgen.org/forums/exha...pipe-pics.html
Old Jun 15, 2010 | 02:18 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Side dumped exhaust is so g@y
Old Jun 15, 2010 | 06:50 PM
i asked for your pictures. not ur opinion. >_<
Old Jun 15, 2010 | 08:03 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Here is pic and my opinion. There so g@y I got them on my car.
Old Jun 15, 2010 | 09:46 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
https://www.thirdgen.org/forums/exha...gh-rocker.html
Old Jun 17, 2010 | 10:30 PM
love the car, specially the hood. y dont u like the side dumped exhaust?
Old Jun 18, 2010 | 05:58 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I like the side dumped exhaust. I was just playin around.
Old Jun 18, 2010 | 02:34 PM
ha. very nice. do u have any problems with them and would u like out the back exhaust more? hows ground clearence i heard its very easy to bottom out. how much did that setup cost you?
Old Jun 18, 2010 | 02:41 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I like them and there loud as f#$k. My exhaust hangs down a little lower because it has to clear my sub frame connectors. The ground clearence is close especially since I went with a 1.75 drop front and back. Definatly need to steer clear of speed bumps cause I wouldnt clear them. The after the headers back cost me $350.
Old Jun 21, 2010 | 12:19 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Here are pictures of the winner of "Best Modified IROC" at the 2007 Carlisle GM Nationals. He had a well-done true dual exhaust that dumped on the sides. Unfortunately, I don't have any pics of the exhaust itself because the car was too low for me to really get any useful pics.
Old Jun 21, 2010 | 06:05 PM
84z28- are you running true duals or what type of setup? did you do it yourself??
that car is pretty sweet. has a wide body kit on it or somthing? thats just how i want to dump put my exhaust with flat exhaust tips.
Old Jun 21, 2010 | 08:37 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
True duals
Headman 68468 long tube headers,S extensions to Moroso spiral mufflers.I put the headers in and I paid some one to put the exhaust together and bend the exhaust. Now that the car is lowered and I have a welder now I can redo the exhaust cause I bottom out now and again cause of such a low ride height.
Old Jan 30, 2013 | 02:26 PM
Redchevy808's Avatar
Car: 1992 camaro rs
Engine: 92 350ci carbed
Transmission: 700r
Axle/Gears: Stock 10 bolt 2:73 gears 😭
Anybody got picture of sides after the tire?
Old Feb 1, 2013 | 12:24 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Sides after the rear tires look like crap-have seen it. I don't even like side exit after the rear tire on truck and they come stock that way.
Old Feb 1, 2013 | 01:28 PM
Twin_Turbo's Avatar
Old Feb 2, 2013 | 07:53 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Problem with a side mounted exhaust is that you lose way too much ground clearance in a street car - unless you cut and notch the pipes into the car. It also makes the inside of the car rediculously loud to drive in since the pipes exit right below your ears.
Old Feb 4, 2013 | 11:23 AM
2007xl50's Avatar
Engine: LB9/3.1
Originally Posted by Twin_Turbo
That is a nice looking set up.
Vintageracer
Jan 10, 2020 05:33 PM
db057
Aug 22, 2015 08:17 PM
Street Lethal
Aug 14, 2015 08:25 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
