Dyno Dons + Y-pipe + no cat + straight pipe, all 3 inches. Enough for a 383?
Old Jun 17, 2010 | 01:41 PM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
If I Replace my exhaust manifold and y-pipe with Dyno Don's, and then have a 3inch straight pipe (no cat) from the y-pipe back along the stock exhaust path to a catback system like (maybe) this one...
http://www.summitracing.com/parts/MPE-16829/?rtype=10
Would that be enough flow for a built 383, or would some sort of true dual system be a necessity? I don't know anything about what the top end is gonna look like yet other than it will be carbed and be just enough to put 350+ at the rear wheels.
Old Jun 17, 2010 | 02:16 PM
NY3RDGEN's Avatar
Car: Trans Am, Corvette
Engine: LB9, LT1
Transmission: 700R4, 4L60
Axle/Gears: 373, 259
Re: Dyno Dons + Y-pipe + no cat + straight pipe, all 3 inches. Enough for a 383?
In short the answer is yes.
But you should be more specific on the 383, Any power adders? ,Intake system, heads cam? street / strip car? Be more specific with the cars overall goals.
But for 350RWHP, the DD headers and magnaflow should be perfect. Sound nice too. Alot of guys go overkill on exhaust, 99% of the time a setup like u want is more than enough.
BTW, Dyno Don headers are prob the best shorties made to fit our cars IMO, wish i had them on.
Old Jun 17, 2010 | 05:18 PM
Zerocyde's Avatar
Car: 88 Camaro
Axle/Gears: 4.11
Cool, thanks for the info. To be more specific, there will be no power adders, and a simple cowl induction hood+open air cleaner + open air lid. It will be a daily driver, and it's primary intention will be to be able to drag nicely, smoke r!cers at stop lights, ect. As far as heads and intake manifold go, I just don't know yet. However I am pretty sure I'll be going for a 4 barrel carb.
Old Jun 17, 2010 | 07:59 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
I hangout with Dyno Don at his shop sometimes. So far here in Socal his headers was used on a 406cu and made 403hp and 439tq. You can't go wrong.
Old Jun 18, 2010 | 07:31 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
For better flow you could build a system like this. If money is not that big of a deal you can't get a better sound and life out of another set. This is made of high quality Stainless Steel for long life span. I've had mine on for 10 years now drive it in snow, icy roads with salt no rust yet. You can build a system modeled after this a lot cheaper just may not last as long. Someone had a post with the flow numbers on a bunch of systems and the best was a straight pipe 2nd was the Borla system. The key to this system is when the muffler builds back pressure the extra pressure goes out the other pipe.
Some places have it a lot cheaper than they do so shop around.
http://www.borla.com/products/produc...=14888&ref=cat
Old Jun 18, 2010 | 02:05 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Suck up.......
just messin!
Old Jun 19, 2010 | 01:17 AM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
lol ya i would imagine that would be PLENTY for your setup. post up a vid whenever your done. and banditexhuast has the magnaflow system for 320 i belive with free shipping. exact same thing but cheaper.
Old Jun 19, 2010 | 08:26 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I have his y pipe with the headers, along with a 3 inch catback. Seems to work great for me. But I did put a 3.5 inch cutout right after the y pipe, since a 3 inch exhaust would not flow enough for me. I only use the cutout at the strip. I would definately buy dyno dons setup. Perfect fit and great workmanship.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
