What is this????
Old Jun 28, 2010 | 01:56 AM
Hyper Tailz's Avatar
Car: 92 Camaro RS
Engine: 3.1
Transmission: Manual
What is this????
Well i was taking off my oil pan and i had to unbolt my exhaust and one of these was cracked. so i am looking to replace it. i just dont know what its called or where i can get it. i already tried autozone places and they dont know what it is and tried serching though the web. this was between the exit of the exhaust manifold and the exhaust itself were u bolt them together. anyone know it would be great help... Name:  CIMG1514.jpg
Size:  54.0 KBName:  CIMG1516.jpg
Old Jun 28, 2010 | 05:18 AM
zachkuby87's Avatar
Car: 1985 iroc z
Engine: 350 .30 over
Transmission: t-5
Axle/Gears: told aftermarket moser 3.73 posi?
Re: What is this????
unless this is something different its an exhaust donut it actually acts as a gasket in between stock exhaust manifolds and the y pipe... take it to your local exhaust shop they should be able to help you out
Old Jun 28, 2010 | 11:03 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
The proper name is Exhaust Flange Gasket . Autozone part number 60538 .
Old Jun 28, 2010 | 11:38 AM
Car: 92 Camaro RS
Engine: 3.1
Thankz to all you guys i am gonna check that out once i am out of work.... hopefully autozone has it if not to the exhast experts
Old Jun 28, 2010 | 11:44 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
You're welcome and they should have it in stock or be able to get it in in the morning for you .
Old Jun 28, 2010 | 02:35 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
The flange gasket is a steel fibre and grafite part, his piece is a solid steel unit that is for taking any mis adjustments out of the manifold pipes.
Please don't buy that AZ part they blow out within a year, go to an exhaust shop and get the actual piece.
Old Jun 28, 2010 | 03:26 PM
zachkuby87's Avatar
Car: 1985 iroc z
Transmission: t-5
one pretty important rule to go by when working on cars is never use autozone parts there junk unless you go in there and get name brand parts which they really dont carry much of.... for that part i would take it to an exhaust shop and make sure they are trustworthy ppl i personally have one exhaust guy hes worked in numerous shops and recently moved to a shop an hour away from home but hes honest and does good work with quality parts so its well worth the trip... find a shop build a relationship with the guys there cause it comes in really handy when ur driving down the road and u start hearing somethin that doesnt sound right or whatever the case may be you can just bring your car in and theyll check it out maybe even fix it free if it doesnt involve new parts......i had my exhaust guy install a cat back i brought the parts for a 24 pack of coca cola one hot *** summer day and there vending machine was broke
Old Jun 29, 2010 | 12:46 AM
Car: 92 Camaro RS
Engine: 3.1
well ok i went to auto parts and got the part that was stated as pqrt number. when i got it it looked like a plastic donut but i thought to give it a try cuz its felpro. piece of poo. the exhaust st sounded like it was gonna fall off . i am gonna try to go to a junk yard and just take one off from there. mine is made out of steel and i thought if it heats up it will get hard or something but when i removed it it looked like it was about to crack from only a few min of use. so yea my search will go on
