Cutout with N/A motor
Old Jul 12, 2010 | 07:05 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Quick question here about cutouts with a N/A motor.
I had bought a 2005 GXP when they first came out. 303hp 323TQ LS4 grand prix. I installed a cutout where the cat was. With the cutout open and closed the car always trapped at 102mph, but with it open i would lose 1-2mph in the 1/8th.
So my question is, Before i start my exhaust will it be worth spending the extra money for an electric cutout, will it be a worthy gain for the price they go for?
Old Jul 13, 2010 | 09:30 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Cutout with N/A motor
on my car I placed the cutout right after the y pipe meets. On the dyno there was a 60 hp difference between the 3.5 inch cutout being open and closed. When its closed its going through a 3 inch edelbrock catback
Old Jul 13, 2010 | 05:18 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
60hp seems alot, i didnt notice any difference with my LS4 at the time, and i placed it after the Y. Was alittle slower on the bottom end
Old Jul 13, 2010 | 09:20 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
my 3 inch pipe was a little dented over the axle, but the dyno showed 60 hp loss with it closed
Old Jul 13, 2010 | 10:40 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
whats your compression? Not sure if that would matter or not, I didnt really look into the specs of the LS4, rather i ddont even know if the compression ratio would make a difference.
60hp is alot of feel in the pants lol and am sure alot more MPH in the 1/4. Like i said i lost mph but still trapped the same
Old Jul 14, 2010 | 03:54 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
That tells me that you've lost some low end torque but gained at the top end. going with a timed cutout would probably help. IE closed at launch and open mid strip.
Old Jul 14, 2010 | 04:14 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
so you guys telling me 300$ IS WORTH IT FOR AN ELECTRIC CUTOUT?
Old Jul 14, 2010 | 04:25 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
why not just do a manual cutout, only cost like 30 bucks
Old Jul 14, 2010 | 04:51 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
had a manual one on my LS4, hated it. Sucked taking it off and putting it on. And i lost bottom end tq and mph.
its electric or its nothing
Old Jul 14, 2010 | 07:41 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
how can you lose bottom end tq and mph with a manual one, as compared to a electric one, when they are the same minus the work it takes to take the end off???
Old Jul 14, 2010 | 09:28 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
manual you take off before you drive the car (obviously) so you lose bottom end grunt, 0-60ish
electric you open up after 60ish and you wont lose the lower end tq
Makes sense too me seeing i lost 2-3mph in the eighth with it open yet still managed to trap the same speed regardless if i had it open or not.
Still trying to adjustify if the electric is worth $300.
Old Jul 15, 2010 | 09:01 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
my car was the opposite. At the track with the cut out closed I had a higher 60 ft along with 1/8 and 1/4 that were also higher
Old Jul 15, 2010 | 04:37 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
no clue, unless its different with carb and F.I.
I ran my car a good 50 times at the track, everything stock but the cutout and muffler.
constant 2.2 - 2.3 60ft
constant 13.7 -14.2 ET
constant 102mph traps regardless and 80mph in 1/8th
cutout off the 1/8th dropped to 77-78mph everytime
Old Jul 15, 2010 | 04:48 PM
skinny z's Avatar
WHERE you put the cut out is the important thing.
Using a program like PipeMax, it can be determined where the "sweet" spot is (so to speak).
So many guys complain that running open headers (or cut outs) on their cars results in no bottom end. Well no *****. The tuning of the exhaust via collector length is one of the most misunderstood aspects of engine tuning that I can think off.
Unless you have access to such a program, the only way to determine the proper location is through trial and error. Track or dyno. Check out the quicker cars at the track or look closely at a high horsepower engine strapped to the dyno. Undoubtedly you will see collector extensions on the order of 18"-24". That's for pressure wave (exhaust pulse) tuning. Free hp if you know what you're doing.
In certain cases, (as mentioned above with damaged exhaust) any cut out MAY provide an improvement. The same would apply if the catalytic(s) were becoming clogged or if the exhaust were hugely restrictive for the horsepower being developed.
Old Jul 15, 2010 | 09:58 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I installed one of those $20 3" summit brand cutouts into my I-pipe it's installed pretty far back it dumps under the rear passenger seat... the car has picked up .25 and 2mph... The car will usually go 11.50-11.60's @ 119mph N/A through the single 3" exhaust and went 11.25 @ 121mph one night with a crappier 60ft with the cutout open.
Old Jul 16, 2010 | 07:11 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Are your guys motors carb? would that even make a difference between FI ?
Old Jul 16, 2010 | 05:07 PM
skinny z's Avatar
It depends on the amount of overlap ground into the cam. From my understanding, EFI cams typically have a wider LSA which in itself reduces the amount of overlap. The actual cam specs would be required so as to make an educated answer.
Old Aug 3, 2010 | 12:31 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
i feel a loss of lower end torque. i run mine open just a bit and it feels good throughout
hydrolic144
Sep 8, 2015 06:55 PM
formula_novice
Sep 5, 2015 03:58 AM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
