Thinking of Building my own Duals
Old Sep 4, 2010 | 06:14 PM
vandal711's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.0 Throttle body injected
Ive been thinking about this setup for a while now.. Im on a real tight budget but Ive been picking through some parts and I think Ive found a reasonable setup.
How does this sound
Pacesetter 3"headers
No cats (none on currently)
two Flowmaster Super 44's
and a set of Black Chrome aggressive angle tips
Any advice [comments, suggestions] on how to run this set-up
Its on a 1988 Pontiac Firebird Formula 305 TBI
Also I was contemplating either Side exits or just oldschool right out the back
Old Sep 4, 2010 | 07:44 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Thinking of Building my own Duals
Good luck getting the two mufflers to tuck and not scrape a bunch of stuff. Also, unless you want true duals just have it, I would personally just by a cat back (doesnt matter if you actually have one) and be done with it. Much easier.
Old Sep 5, 2010 | 10:32 AM
antsZRS's Avatar
Car: 1990 Camaro ZRS
Engine: 350 SBC
i have true duals, and i used to always have ground clearance problem, nevertheless i have tucked them up quit a bit more and i havent scrap not once since i re-did it. i went from regular mufflers to bullet type mufflers and was able to get more clearance than i thought. just a lil fyi. as long as u can tuck them up u will be great. good luck!
Old Sep 5, 2010 | 02:23 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
i also have duals, stockish ride height(27" rear tire not much difference) and don't really scrape that much, and the shop that did them didn't do too great a job. as for fitting the mufflers, i'd knock the rear seat pans in get yourself a little more room. theres a guy on ls1tech that actually cut the pan out and replaced it with sheetmetal higher up so he could fit a flowmaster. i'll see if i can find the thread and link it.
here it is. http://www.ls1tech.com/forums/multim...pics-vids.html
Old Sep 6, 2010 | 06:05 AM
vandal711's Avatar
Thanks guys, And yeah Im going for true duals.
Ill try some things and let you know how it goes
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
midge54
Jan 29, 2017 07:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
