Is this hole supposed to be there?
Old Sep 13, 2010 | 01:53 PM
Camatruder's Avatar
Car: 88 Camaro V6
Hi,
I had my muffler sandblasted and powder coated and now I notice a little hole between the two pipes. Did the sandblasting shop do this or does it serve as some kind of drain hole. I hadn't noticed it when the muffler was still rusty but it kinda looks like it's drilled. And off course, there's smoke coming out of it.
As far as I know, it's a stock muffler.
Thanks.
Old Sep 13, 2010 | 01:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Is this hole supposed to be there?
Looks like a drain to me, too.
Old Sep 13, 2010 | 02:43 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Every stock muffler I've ever seen has that hole. While I have no idea what its for, a drain is a very likely explanation.
Old Sep 13, 2010 | 02:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They are drain holes, to keep condensation in the muffler from rotting it out from the inside.
Old Sep 13, 2010 | 03:13 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
just to confirm what everyone has already said, that is a drain. third times the charm
Old Sep 14, 2010 | 12:58 PM
Camatruder's Avatar
Car: 88 Camaro V6
Thanks guys.
Old Sep 15, 2010 | 07:25 AM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
How is the powder coating holding up? Did you coat your entire system? More pictures?
Old Sep 15, 2010 | 10:23 AM
Camatruder's Avatar
Car: 88 Camaro V6
I painted the front pipes and the catalytic converter with heat resistant paint that withstands temperatures up to 650 °C.
I measured the max. temperatures on the intermediate pipe, muffler and tailpipes with an infra red meter. At the front part of the intermediate pipe I measured about 120 ° C. Futher rear it was much less. The guy from the powder coating shop told me that temperatures up to 150 ° C are no problem so I let him powder coat these parts.
Because the car is an on going restoration project I only had it running once on idle with the treated parts. So far it held up fine.
Pac J
May 17, 2020 10:44 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
GageBrand
Oct 22, 2015 02:30 PM
88CamZ
Oct 8, 2015 10:29 AM
drumstixer
Sep 29, 2015 03:02 PM
