Fourth Gen Exhaust, Will it work???
Old Sep 21, 2010 | 10:22 PM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
I was wondering if a fourth generation camaro exhaust will fit on my 1991 camaro tpi? It seems as if they look identical because of the Y-Pipe, but does the tpi part make the exhaust sound nasty? I was looking into a corsa fouth generation exhaust, but the online help there wasnt much help just telling me its meant for a 4th gen when i already knew that. Any think it will work or is it not worth it? Will it sound nasty?
Old Sep 21, 2010 | 10:54 PM
87_TA_GTA's Avatar
Car: 87 T/A GTA
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Re: Fourth Gen Exhaust, Will it work???
im pretty sure that it will work, just need to have the hangers relocated on the exhaust since theyre different on 3rd gens.
Old Sep 22, 2010 | 12:06 AM
Drew's Avatar
-deleted
Old Sep 22, 2010 | 05:31 AM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
If i take it to a shop to have it re welded will it work? Also how would you think it sound?
Old Sep 22, 2010 | 09:36 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I've had 4th gen exhausts on my 86 and my 88. Pacesetter from a 95 TA on my 86 and a Borla from an unkown 4th gen on my 88 Formula.
Rear hangers are in the same place as well.
If you take it to a muffler shop they can mount it up and fix any irregularities that might be present.
Corsa should sound pretty decent.
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
TheExaminer
Aug 26, 2015 04:59 PM
InfinityShade
Aug 22, 2015 08:00 PM
Linson
Aug 21, 2015 02:12 PM
