Exhaust(ing)
Exhaust(ing)
Will a complete exhaust from a 2002 WS6 trans am thaat is complete from manifold, y-pipe, 2 oem catalytic converters, muffler, chrome tips, and all the tubing in the exhaust fit on an 86 Camaro?
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
Re: Exhaust(ing)
As far as I know yes, are you getting an good deal on the whole exhuast or something?
Edit: actually the manifolds wont fit.
Car: 87 GTA
Re: Exhaust(ing)
You'll need to get headers that are designed for true duals on 3rd gens to start with, but no way it'll be a 100% bolt-on. The y-pipe (at least) will need to be modded to work.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Exhaust(ing)
no it will need some modding, doubt the converters fit bolted right onto the manifolds with our frame up front. Then you'd need a custom y-pipe and the catback shouldn't be too much an issue at least.
Re: Exhaust(ing)
yes - this is on craigslist for $200 -they upgraded their 4th gen... I am working on an 86 that doesn't have an exhaust system yet and thought this might be a good start.. (the previous system rusted and fell off at the cat!)
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Exhaust(ing)
only the cat back will work, and even that will require modification. manifolds, y, and cats are completely different and not worth the headache to make fit
david068513
Sep 18, 2015 10:36 AM
