Which exhaust will support and be good for my setup?
Old Oct 3, 2010 | 11:55 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
I'm building a forged l98, afr 190 vortec heads, slp ported runner, ported plenum. Will most likey go HSR soon. Also will be spraying 150 shot and will eventually strap a D1 to it. I want to run longtubes, should I go y pipe or x? What headers will support the power I'm going for (550-600 rwhp) and flow the best.
Old Oct 4, 2010 | 01:55 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Which exhaust will support and be good for my setup?
Why are you wanting to run longtubes?
Old Oct 4, 2010 | 06:38 AM
Axle/Gears: G92
I don't see why you wouldn't run longtubes, more high end power, only thing that can support higher horsepower or if I step up th boost. Better sound.
Old Oct 4, 2010 | 06:59 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I vote for long tubes. Make sure you have the transmission and torque arm configuration you want before you plan the exhaust. Mine are coated 2210s into the Mufflex Y-pipe that I had to dent slightly to get it around the Spohn TQ Arm and then I built my own 4" exhaust on back to a Hooker Muffler and it dumps on driver side with 4" turn down tip.
You're going to have some issues with long tubes. I had to notch the rear A Arm mounting flange to get clearance. You might have issues with the oil cooling tubing also. I didn't reuse mine so I don't know.
You could also look into some Dyno Don headers I believe he makes some that follow the OEM path.
Old Oct 4, 2010 | 02:37 PM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
With the ground clearance problems, the room they take around the engine and the minimal HP loss with shorties they seem to be outdated these days. You have seen the shorties that Dyno Don makes and the video on a Dyno. His headers will be less of a headache when working around the engine or drag like lonetubes. I bought a set for a Mustang I had. I could only get lonetubes and they would drag all the time. Get two people in the car and you could forget about going to a parking lot with speed bumps. My RS is stock ride height and drags a lot now. I have shorties on it I would hate to see what longtubes would do.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
db057
Aug 22, 2015 08:17 PM
