y pipe question.. Ball and Socket Type Flange or Slip-On Flange
Old Oct 26, 2010 | 11:50 PM
imRICH23's Avatar
Car: 88 vert iroc & 95 586hp trans am
Engine: 355
Axle/Gears: 373
pro and cons. i have ne idea which one i need to get.
http://www.jegs.com/i/Hedman/500/17478/10002/-1
vs
http://www.jegs.com/i/Hedman/500/17470/10002/-1
for these headers
http://www.jegs.com/i/Hedman/500/68476/10002/-1
Old Oct 27, 2010 | 12:31 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: y pipe question.. Ball and Socket Type Flange or Slip-On Flange
You're buying the headers at the same time? I think they come with ball-and-socket flanges now, but it might be a good idea to call Jeg's and make sure they're going to send you something that matches.
Old Oct 27, 2010 | 11:25 AM
lowridetractor's Avatar
Car: 89 Iroc-Z
Engine: 350/carb
Transmission: th350
summit suggest to use this one.
Old Oct 31, 2010 | 03:03 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
For what its worth
For the 17478 model, the spec indicates ball & flange, which, if you have
good eyes or a magnifying glass, can be confirmed.
The 17470 model has the same basic flange configurations, the difference
being that ONE connector is a slip-in fit, allowing for adjustment.
And I can definitely attest to the benefit of such adjustment.
(I personally would weld the pipe in after final fit, but that's just me.)
Others can chime in here, but I wasn't able to find flat flange fittings
on y-pipes, unless it was a matched set header/y-pipe combo by the
same manufacturer. Maybe its a quality-control/cost-to-manufacture thing.
Other members have claimed to be able to get proper sealing with the
outer portion of ball-flange, against the flat flange. Obviously, a better,
thicker gasket would be a good idea.
Good luck.
Old Nov 6, 2010 | 11:27 AM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Apeiron has it right. Are the headers you have ball and socket of flat gasket? You need to make sure they match or you just spent money then waited just to have to send them back and get the right one, plus shipping both times. I have the hedman 68470 with a flat gasket so I will need to use the 17470 y-pipe. 109.99 from summit.
MAKE SURE THEY MATCH.
Old Nov 6, 2010 | 05:31 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i have hedman headers #68478 with Y pipe #17478 . ball & socket , i'm happy with fit . good luck .
Old Mar 29, 2011 | 07:30 PM
imRICH23's Avatar
Engine: 355
Axle/Gears: 373
any pics of this system? mines doesnt look like itll work.
Fronzizzle
Feb 9, 2017 09:31 AM
sreZ28
Oct 22, 2015 08:21 AM
Eric-86sc
Sep 22, 2015 08:25 PM
roysatikas
Sep 22, 2015 08:15 PM
Hello, Michael
Sep 11, 2015 01:10 PM
