Flames out of the tail pipe
Old Nov 3, 2010 | 04:08 PM
Shane4524's Avatar
Car: 1986 Camaro IROC Z28
Engine: 5.0L 305 TPI
I hope this is an alright place to ask this, but in the fast and furious movies they have flames coming out of the tail pipes. I am curious as to how this works? Can someone describe how the setup would be on a thirdgen?
Old Nov 3, 2010 | 09:03 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Flames out of the tail pipe
Movie magic.
...the only 'good' way to do that in reality, if all you want is just the visual, is to get a flamethrower kit, and those only work on carbureted engines with manual chokes. I wouldn't recommend it on a car with plastic bumpers though.
Old Nov 3, 2010 | 09:16 PM
mexicanknight's Avatar
basically what those things do is cut the spark, and send raw fuel through the exhaust where another spark plug ignites the raw fuel.
Old Nov 17, 2010 | 12:01 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
you can also get kits that use propane piped into the tailpipe and an ignitor (usually spark plug hooked up to a switched electrical source), but its a lot of work to look ok and not melt anything
Old Nov 17, 2010 | 12:18 PM
mightymaro94's Avatar
Originally Posted by Air_Adam
Movie magic.
Old Nov 17, 2010 | 01:28 PM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
I had a flamethrower kit on my car but it wouldnt work with my TPI setup and flowmaster 80 series. My timing jumped one day and I started shooting flames out of the exhaust if i was really on it and would let out. It was pretty badass lookn at night! lol but I switched to carb now and may put the kit back on but i doubt it, its just not worth it and u really dont get the look u want. IMO
Old Nov 17, 2010 | 04:14 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
http://www.vimeo.com/16824546
Minute 5:28
His only happens off throttle, stock computer, relatively stock motor, guy can't figure out why it does it. Definetly NOT a performance advantage or desirable.
Old Nov 17, 2010 | 04:54 PM
Twin_Turbo's Avatar
in the f&f they also use naws to blow intake welds, the cars have 25 gears and all other kinds of stupidity. \
Time to watch some mechanical videos (like the free ones on youtube) to cure that Hollywood movie poisoning
Old Nov 17, 2010 | 04:58 PM
Originally Posted by Twin_Turbo
in the f&d they also use naws to blow intake welds, the cars have 25 gears and all other kinds of stupidity. \
Old Nov 19, 2010 | 11:03 AM
Pocket's Avatar
Car: 91 Trans Am
Same thing happens in NASCAR, always when they let off
http://www.youtube.com/watch?v=H1rQEW27KXg
Old Nov 19, 2010 | 11:49 AM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
[quote=GMan 3MT;4737654]http://www.vimeo.com/16824546
Minute 5:28
great movie!! makes me wanna go get a roller and throw a 350 in it and go have some fun 12:42 was funny the two camaros passed that shelby like it was sitting still
Old Nov 20, 2010 | 12:24 AM
EvilCartman's Avatar
Car: '82 Z28
Had flames coming out of mine when I had too rich of a tune on the nitrous, oops.
Old Feb 22, 2011 | 02:27 PM
benji84cam's Avatar
Car: 84' camaro SC
Engine: 2.8l carb
I think I can fix all these problems im about to do the same thing with my car I have a 84 and what im gonna do use camping propane tanks there small and cheap i already have one and i have installed a safety switch in my dome lamp and an ignition push button in my ashtray slot(lid still closes) and a sprinkler solenoid for the fuel cut off i got 2 cheap car spark plugs im gonna install in each exhuast pipe about 4-5 inches from the tip and fuel line about 2-3 inches behind using metal propane hose to prevent heat problems as for ignition you can pick up coils for like 9 bux and find a wiring diagram on youtube for the electrical set up ill take pics of my progress I have already got the toggle safety and ignition button in place
Old Feb 22, 2011 | 02:46 PM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
Flame Thrower kit... But people are fail to mention they're illegal in most(if not all) states to use lol
Keep it in the movies, not on the real streets
Old Feb 22, 2011 | 08:16 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Go ahead burn your car to the ground!!! WTF, this ain't Hollywood, did you read the posts about plastic bumpers???? If not, read it again please....
Old Feb 23, 2011 | 05:29 PM
benji84cam's Avatar
Car: 84' camaro SC
Engine: 2.8l carb
my exhaust pipes aim down plus since its propane its not gonna flare upwards and im not dumb enough to use it on the streets its a show thing
Old Feb 23, 2011 | 06:45 PM
J91's Avatar
J91
Ok...
Old Feb 24, 2011 | 09:11 AM
Andrew1320's Avatar
Car: 1990 Pontiac Firebird
Engine: V8,350,5.7 L.
Transmission: Automatic - 700r4
Sounds pretty cool but sounds like a huge waste of time and money to me.
Old Feb 24, 2011 | 10:30 AM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
most the cars I've seen with them were 50's hot rods and they have a big flame retardent blanket they put on the trunk lid to protect the paint . The nascar guys have a flame off throttle because of all the raw fuel hitting the almost 1000 degree pipes , it goes out when they get back on the gas .
Old Feb 24, 2011 | 11:28 PM
89Camaro89MI's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
I've heard you can rig the spark device out of a barbecue lighter to the end of your tailpipe and get something of a fireball. As mentioned above, you essentially need an engine that's running rich.
If you just want some cheap fun, you might try running like an IV tube from a syringe to about 10 inches from the tailpipe and fill it with gas. Use some brake line near the hot exhaust pipe. Push the plunger and your exhaust will aerate the raw gasoline. might work. I've thought about doing this for giggles.
In the movie, if memory serves, the flames were caused by nitrous oxide which is silly.
Old Feb 26, 2011 | 04:54 PM
Pocket's Avatar
Car: 91 Trans Am
Sounds like a good way to blow your tail pipes off
Old Feb 26, 2011 | 05:13 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
my srt4 threw about a 1 foot flame after a wot run . it was running real rich an had no cat or mufflers . plus i was spraying denatured alcohol .
Old Feb 27, 2011 | 05:46 AM
jtlockwood88's Avatar
Car: 88 Formula 350 / 87 Iroc 68k miles
Engine: 355 / 355
Transmission: 700r4 / 700r4
Axle/Gears: 10bolt w/3.23 - 9bolt w/3.27
My old firebird did it as well but stopped after the timing was adjust maybe one of the previous owners thought it would be cool or something, lol. it only happened if you revved it right and basically crackle or pop, maybe something like a back fire, kinda hard to explain anyways it was kinda fun to mess with people with it one time i really freaked out a soccer mom in her minivan when she was tailgateing me. also it usually blew out a foot or two
Old Mar 5, 2011 | 12:25 AM
Skribb's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6 mpfi .40 over
Transmission: 700R4 stage 2 shift kit
Axle/Gears: 3.42 factory
if seriously want it to do it despite killing your bumper and anything else pretty much run just straight pipe no cat or nothing all the way back and for some reason they seem to work better 1 or 2 of those stupid cannon mufflers all the imports seem to have make it run rich with slightly off timing and have at it will mainly do it on wot and let off after but i dont suggest it ran an old S10 that way that had a 2.8 mpfi from an 88 rs in it. it looked i guess could say cool foot long flame and random fireballs and lit the whole rear end up at night but the cost?? burnt valves multiple tickets and fines and constant plug cleaning/replacing before the motor said screw it and went out the door its not worth the damage if you really care for your car let the movie crap stay right there in the movies 3rd gens are not made to shoot flames like that only old hotrods
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
