What to use to repair cat A.I.R. tube?
Old Jan 13, 2011 | 03:21 PM
SpeedRacerX's Avatar
So I've been doing some work on my exhaust and I just bought a magnaflow cat. I had to cut a section out of the air tube that goes from the A.I.R. system to the original cat because it was welded. (By original cat, I mean the one that was in when I bought it, but not necessarily stock). Anyway - What is the best material to use to repair the tube? I need about 6" of tubing. I'm not really sure what kind of metal the tube is so I don't want to just go buy galvanized conduit from home depot because if the metals are dissimilar they will corrode. Does it have to be a metal that can withstand high amounts of heat or does it stay cooler than the exhaust?
Old Jan 13, 2011 | 03:44 PM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
Re: What to use to repair cat A.I.R. tube?
Not that this helps but when i got a magnaflow cat i just pulled the whole cat part out of the car but left the AIR injectioninton into my headers. its an option and easy to do
Old Jan 13, 2011 | 09:51 PM
IAGTA's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 w/SLP cold air intake
Axle/Gears: 9 Bolt 3.27 with PBR brake upgrade
Walker 35574 is a kit that I recently purchased to re-connect the factory AIR tube to my new cat. - had to cut the old tube off just past the clamp. Does it work? I don't know yet but it has a lot of pieces that can be used to adapt the original pipe. Interesting that the original factory pipe is chrome. I don't believe there is a lot of heat where this pipe connects to the cat but I could be wrong. I was going to purchase some aluminum tube to make the connection (using anti-seize to prevent corrosion) and may still be forced in that direction if this Walker kit doesn't work.
jrdturbo
Mar 31, 2016 02:58 PM
Johnny*G
Oct 20, 2015 12:37 PM
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
75bike
Sep 20, 2015 09:37 PM
