New exhaust, need to pass emissons
Old Jan 22, 2011 | 09:39 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Got the car 2 years ago and barely passed the third time. The shop I took it to back then said I passed once the cats were hot. Exhaust looks like it's the original with the exception of the headers, which look like long tube headers. I've been thinking about getting a magnaflow setup with mid lengths and possibly going back to the 195* thermo. The car was running very rich is what I was told. I feel that my 02 sensor may not be getting hot enough with the longtubes and lower thermo. Does anyone think that the Magnaflow setup with midlengths, and possibly higher thermo (at 180 now) get me through? I also have an exhaust leak if that means anything as far as emissions.
Old Jan 23, 2011 | 01:20 AM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Re: New exhaust, need to pass emissons
All I can tell you is that its very easy to switch to a heated o2 sensor.
How does your car even have room for cats if it has long-tubes? Where are they?
Old Jan 23, 2011 | 05:08 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
A heated O2 may be all you need. Plus some of these smog guys are idiots anyway. The cat does not work unless its hot. These guys will test on a cold motor and it will fail.
Do you have a smog print out that you can show the results?
Running rich I am thinking maybe too high HCs. How was the NOx? Where are you or does your state test all these things?
You can also check your timing if the test station did not or said it was ok and maybe replace the cat.
Old Jan 23, 2011 | 10:50 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I dont think you need to change your headers. but if the cats are original they probably need changed.
Old Jan 23, 2011 | 05:18 PM
Mr Froman's Avatar
The exhaust wraps way to the right, cat is under the passenger seat pretty much. The timing was adjusted about a month ago so we'll see how that goes. And it wouldn't surprise me if the cat does need replaced because the exhaust on the bird is pretty shot. I planned on getting my exhaust done anyway.
And I will look into the heated O2 sensor, I never heard of that before.
Old Jan 23, 2011 | 05:24 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Where did it fail at??? You really can't get the proper answers unless you tell us.
The Cat and EGR a usually the two big heavy hitters but it still helps to know.
And later vehicles, at least 96+ are heated O2. They save on the time it takes for the exhaust to heat the O2 itself as they also need to be hot to be working.
Old Jan 24, 2011 | 02:41 PM
Mr Froman's Avatar
Delaware. I'll see if I can find my old numbers they printed out for me. Did put a new EGR a couple months after inspection because it went bad. I may actually get through this time, just anticipating another failure because she does run rich still, I even get an SES once in a while. Pull the codes and its Oxygen Sensor Rich Detected.
gta892000
Aug 11, 2019 11:16 AM
customblackbird
Oct 1, 2015 04:30 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Djmathis123
Sep 8, 2015 08:42 PM
89fast5oh
Sep 8, 2015 09:55 AM
