HEADER/EXHAUST HELP!!! WITH SPECS
Old Feb 10, 2011 | 02:41 AM
tsmoke355's Avatar
Car: 1991iroc
Engine: 5.7 355
Transmission: 700r4 w/ transgo shift kit
Have a 78 small block 355 tpi with a set of 305 h.o. heads.. hyd comp cam (12-242-2). rebuilt bottom and top end. runnin 30#injectors. will a set of 2055 headers w/ air tubes and y pipe with high flow cat and magna flow 3 in catback( single cat) hurt my motor or will i just be loosin a couple extra horse power compared to a true dual(2 cat with x pype)?just ordered the cat back today... can i use this for wat i have or will it be bad for my motor??? please help. already have my new ecm and prom tuned for emmisions from aztpi. last is wiring harness.. then im done. gotta have it running by march 27..
Old Feb 10, 2011 | 05:20 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: HEADER/EXHAUST HELP!!! WITH SPECS
Those headers will be fine along with a 3" single exhaust. More power could be had with long tubes and or 1-3/4" shorties but the hassle of fitment, fab work, and rareity of 1-3/4" headers, might make it not worth the effort. Dyno Don may make a set that you might want to look into.
Old Feb 10, 2011 | 06:46 PM
tsmoke355's Avatar
Car: 1991iroc
Engine: 5.7 355
so the 2055s are not 1 3/4in and a shorty? i need airtubes and coated. wanted long tubes but need to pass emissions.
Old Feb 10, 2011 | 07:03 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The type of header you chose has less to do with emissions than the overall tune of your combo. If you are worried about emissions you should leave your car stock and or take some time to reasearch a good "tune-able" combo that will make the sniffer police happy. Make sure you use a 3 way cat with AIR tube.
The 2055's are non coated 1-5/8" shorties with a 3" y-pipe. They have AIR tunes and are a really good set of headers. You can send them out to have them coated at a reputable coating shop. Most headers do not come coated, and if they do the coating is often poor.
Old Feb 10, 2011 | 07:42 PM
tsmoke355's Avatar
Car: 1991iroc
Engine: 5.7 355
well i want 1 3/4 inch. shorties. coated i was gonna have them coated by summit, then sent to me.everyone talks dyno dons headers.?
Old Feb 10, 2011 | 08:02 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The only shorties you are going find in 1-3/4" are used SLP's and or new dyno dons. I have heard nothing but good things about dyno dons headers. I would plan on having your headers coated after you buy them. Headers that come "coated" are often done poorley. There are many companies that do a fantasic job at ceramic coating. Jet Hot is one and American Coatings is another. I am sure there is a coater within your state as well.
Old Feb 10, 2011 | 08:14 PM
tsmoke355's Avatar
Car: 1991iroc
Engine: 5.7 355
where can i get dyno dons?
Old Feb 10, 2011 | 08:26 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
A quick search on this website . His user name is the same as his product.
Old Feb 11, 2011 | 11:38 AM
tsmoke355's Avatar
Car: 1991iroc
Engine: 5.7 355
Hey thanks alot man.got a hold of him. Be ordering mine next check...appreciate the advice..
Old Feb 11, 2011 | 02:13 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Why such big injectors? You will probably be fine with a 3" single ypipe too.
Old Feb 11, 2011 | 02:27 PM
tsmoke355's Avatar
Car: 1991iroc
Engine: 5.7 355
Goin hsr. After its runnin and I get it to pass emissions. tpi is temp.
Old Feb 11, 2011 | 02:33 PM
ninetyone's Avatar
Axle/Gears: 3:42
Just wondering. Did you already upgrade the stock 305 heads valve springs yet? Did you get your tune set up for hsr intake with the 30lb inj?
Old Feb 11, 2011 | 02:34 PM
ninetyone's Avatar
Axle/Gears: 3:42
The 350 heads would flow more you know. You would be putting out 300 hp +, if you put on some truck Vortec heads and changed your tpi base to the scoggin dickey one, you know.Are you going for a street car or a high rpm track car?
Old Feb 11, 2011 | 03:04 PM
tsmoke355's Avatar
Car: 1991iroc
Engine: 5.7 355
No. To my intake.The people at az tpi are takin care of me.Though.Ya new lifters valves springs. the whole Kit from summit.
Old Feb 11, 2011 | 03:08 PM
ninetyone's Avatar
Axle/Gears: 3:42
Well ,i hope you keep us posted on how it goes. I am curious to see what kind of gains you will get with the HSR.
Old Feb 11, 2011 | 03:17 PM
tsmoke355's Avatar
Car: 1991iroc
Engine: 5.7 355
Ya I know didn't wanna have to swap heads. Keepin as is till its up and running because I have not even driven this car yet. Had it for a yr and procrastinated to the last 3 months i have done.Headers. Exhaust .ecm. prom and tune cam and lifter set. New painless harness.injectors. fuel pump.water pump.balancer . New paint job on motor. Next is rear end.hsr.heads
Old Feb 11, 2011 | 03:24 PM
ninetyone's Avatar
Axle/Gears: 3:42
What gear are u running now?
Old Feb 11, 2011 | 03:35 PM
ninetyone's Avatar
Axle/Gears: 3:42
sounds like you are ready for some nice heads.
Old Feb 11, 2011 | 03:36 PM
tsmoke355's Avatar
Car: 1991iroc
Engine: 5.7 355
Well the car originally is a 90 rs. and I haven't exactly checked but has a ten bolt in the back.gotta run the numbers to be exact
Old Feb 11, 2011 | 03:44 PM
tsmoke355's Avatar
Car: 1991iroc
Engine: 5.7 355
Heads wouldtop it all off and be huge.I just wanna get it runnin first. Car deff has potential.
Old Feb 11, 2011 | 03:48 PM
tsmoke355's Avatar
Car: 1991iroc
Engine: 5.7 355
And street car. For now. Hsr and rear end plus heads then track car. but that's not for couple months. My new daily driver will be and 87 vette.(sorry not a maro) but close great deal... hopefully 3 months
Old Feb 11, 2011 | 04:15 PM
ninetyone's Avatar
Axle/Gears: 3:42
just check your rpo codes in the rear hatch door. Should say somethoing like gu2, or gu5. Look for that combo.
Old Feb 11, 2011 | 04:49 PM
tsmoke355's Avatar
Car: 1991iroc
Engine: 5.7 355
Rear hatch open.where abouts ?
Old Feb 11, 2011 | 04:51 PM
ninetyone's Avatar
Axle/Gears: 3:42
open your rear hatch and look to the left at the sail panel, there should be a little plastic door with a key/lock. In the cargo area, if you were to look to the right then that side holds the spare tire behind it.
Old Feb 11, 2011 | 04:53 PM
ninetyone's Avatar
Axle/Gears: 3:42
Basically the little storage compartment in your trunk. You open it with your trunk key
Old Feb 11, 2011 | 04:57 PM
tsmoke355's Avatar
Car: 1991iroc
Engine: 5.7 355
Ya but n gu2 or gu5
Old Feb 11, 2011 | 05:16 PM
ninetyone's Avatar
Axle/Gears: 3:42
It should be in there. Gu-something. Look again
Old Feb 11, 2011 | 05:17 PM
ninetyone's Avatar
Axle/Gears: 3:42
GU1 : AXLE REAR, 2.41 RATIO
GU2 : AXLE REAR, 2.73 RATIO
GU4 : AXLE REAR, 3.08 RATIO
GU5 : AXLE REAR, 3.23 RATIO
GU6 : AXLE REAR, 3.42 RATIO
Old Feb 11, 2011 | 05:29 PM
ninetyone's Avatar
Axle/Gears: 3:42
BW 9-Bolt RPO Codes:
GH3 = 2:77
GW6= 3:27
GM3 = 3:45
look for those too. Maybe you have a 9 bolt rear!
ninetyone's Avatar
Axle/Gears: 3:42
Let me know dude.
Old Feb 11, 2011 | 06:32 PM
tsmoke355's Avatar
Car: 1991iroc
Engine: 5.7 355
there is ten bolts will check codes when back home
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
angel2794
Sep 8, 2015 06:22 PM
