heat riser-open or shut?
Old Feb 12, 2011 | 10:39 AM
j.prince428's Avatar
Car: 1983 Z28
Engine: 5.7
Axle/Gears: UNKNOWN
I'm doing away with all my emissions and obd in my 83 z28. Just one question. Is the butterfly in the heat riser open or closed with no vacuum to it?
Old Feb 12, 2011 | 11:15 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: heat riser-open or shut?
Open. You can remove the butterfly or simply replace the whole business with a spacer from a TPI car.
JamesC
Old Feb 12, 2011 | 12:26 PM
Car: 1983 Z28
Engine: 5.7
Axle/Gears: UNKNOWN
So leaving it there not hooked up would work as well?
Old Feb 12, 2011 | 01:57 PM
JamesC's Avatar
I'd be surprised if it's not frozen open or partially open at this point. Might be worth a look.
JamesC
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
