tick or leak?
Old Feb 23, 2011 | 04:22 PM
walkthelin3's Avatar
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
tick or leak?
ive had a tick since i bought this car.. ive heard that if it ticks on idle then its a valve tap.. if it gets louder under stress then its exhaust... well the car ticks and sounds like a motorcycle at idle.. and it gets louder under stress..i hope to god this is an exhaust leak.
Old Feb 23, 2011 | 04:44 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Re: tick or leak?
http://www.youtube.com/watch?v=uTmaQ1XBASk about fifteen seconds into this video is exactly how mine sounded when a header bolt was loose.
Lifters sound like this http://www.youtube.com/watch?v=hLV7NdtZ5J0 and dont get louder, just faster.
Old Feb 23, 2011 | 05:37 PM
Axle/Gears: 3.47
Re: tick or leak?
sounds like both to me... http://www.youtube.com/user/ChubbyLo...-d9MRvI----its 3 quarters of the way through when i run the motor
check the camaro videos. thts mine
Old Feb 25, 2011 | 11:31 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: tick or leak?
Check for loose manifold/header bolts. Mine were the last two on the drivers side. Fixed
Old Feb 26, 2011 | 09:39 AM
torque_is_good's Avatar
Re: tick or leak?
what are the realistic (99% chance will actually happen because you have the money) plans for the car over the next 6 months?
If nothing, then fix your exhaust leak and just run heavier motor oil until the engine gives up the ghost.
If you have plans to replace, then do nothing other than run heavier oil.
Honestly, I don't know if I would even bother fixing the exhaust leak. Unless you are prepared to possibly replace a lot of piping, you might be dealing with severe rot/rust so why disturb it.
Old Feb 26, 2011 | 12:50 PM
uummm's Avatar
Car: 92 rs
Engine: 305 boat anchor
Transmission: t5
Re: tick or leak?
just put headers and duals on it, thats what i did. i figure later when i go to a larger displacement motor (350 from the boat anchor 305) everything i need from the 305 will bolt up. one great reason to love chevys, they make alot of things universal.
Old Feb 26, 2011 | 01:50 PM
Sparkytfl's Avatar
Re: tick or leak?
Going along with torqueisgood's last statement, somebody a couple weeks ago had this problem, tried tightening the bolts, being original and rusty, one broke. So its possible you might want to leave it be for now, because a bolt thats a little loose yet still there holding the manifold on is better than either having no bolt there, or having to completely remove the y pipe and manifold so you can extract a broken bolt and replace them all. Unless you wouldnt mind all that work.
Old Feb 26, 2011 | 07:01 PM
Axle/Gears: 3.47
Re: tick or leak?
took it to a place.. couple bolts r broken on each side
Old Feb 26, 2011 | 07:04 PM
Axle/Gears: 3.47
Re: tick or leak?
the piping on the car is rather knew(no rust) got it like that. the only rusted area is the flange n the pipes going to the manifold n the manifolds themselves. have a set of pacesetters in the trunk...
Old Feb 27, 2011 | 07:38 AM
89rs358's Avatar
Car: 89 rs 358 / 99 wrangler 4.0
Engine: 358
Transmission: t5
Axle/Gears: 393 12 bolt
Re: tick or leak?
im no expert on reciprocating engines as i work on turbines, but ive had a few cars with lifter problems and this is how i have always determined the difference between an exhaust leak and a lifter tick-
get the engine started and let the idle normalize, dont let it warm all the way up tho, move the throttle by hand a little at a time, if the "tick" goes away after 1200-1700 rpms chances are the increase in oil pressure is forcing some into the valves lifter, and it is a lifter problem, if the tick persists with engine speed chances are it is an exhaust leak
Old Feb 27, 2011 | 10:41 AM
Axle/Gears: 3.47
Re: tick or leak?
then its deff an exhaust leak
Old Feb 27, 2011 | 04:24 PM
89rs358's Avatar
Engine: 358
Transmission: t5
Re: tick or leak?
my 89 camaro had a small exhaust leak at the collector (where the header joins the exhaust pipe, should be 3 bolts) easy way to determine if it is leaking there is to put a peice of paper down by it and see if it "flutters" arouns from leaking exhaust (dont leave it to long or get to close unless you want some fire tho :P)
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
