Options for the dual cat setup?
Old May 12, 2011 | 03:06 AM
swisscheese's Avatar
Car: '91 Z28
Engine: LB9
I have the stock dual cat setup on my car with Hooker shorty-headers and the borla catback.
Now I have to replace one of the cats. So far I found the Magnaflow setup (36479) with seems to bolt right up.
Is this any good or are there other better options?
I know that this question must be asked a few times, but I didnt find an actual thread about this.
Old May 12, 2011 | 10:22 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Options for the dual cat setup?
36479 must be the one with the new cats. (old...23479)
Here is a picture of the old setup and what you need to do to make it fit.
I have marked where it needs to be cut, then you need to build new connections to connect to your headers.
Also the end narrows down to 2 3/4" so cut it and add a 3" connection.
Old May 12, 2011 | 11:03 AM
Car: '91 Z28
Engine: LB9
Summit lists the 36479 as 50 state legal and the 23479 as 49 state legal
Old May 13, 2011 | 01:30 AM
Car: '91 Z28
Engine: LB9
its not hooker-brand headers, there are hedman shorties 66491 so probably this makes it easier to mount!?
are there other possibilities? should I just buy two new converters?
Old May 13, 2011 | 04:13 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I have this dual cat, brand new in box, taking up place in the basement http://www.summitracing.com/parts/CTO-4153/ PM if interested.
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
