question about my exhaust
Old May 23, 2011 | 06:07 PM
razman340's Avatar
Car: 1985 Z28
Engine: 305ci 4barrel
Transmission: 5-speed
85' Z28....305 four barrel..car just recently started idling rougher and real loss of power on road. could the catalytic converter be plugged up? are these symptoms what you would expect? i believe this is the original converter on the car (120k mi on car)
is there an easy way to determine if this is my problem? can't these cats be punched out and gutted? how do you go about doing that? Rick
Old May 23, 2011 | 06:34 PM
dannyboyemt's Avatar
Car: 89 RS,02 WS6 M6,08 GMC Sierra SLE
Engine: ZZ4HCI, LS1, LY5
Transmission: T5/T56/4L60E
Axle/Gears: 323,342,373
Re: question about my exhaust
pretty sure u can tap on your cat and if you hear rattling inside its bad
Old May 24, 2011 | 10:33 AM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
I believe a cat problem wouldn't come on suddenly, especially with a carbed car. Sounds more like a vacuum line came off or some other carburetor problem.
Old May 25, 2011 | 01:09 PM
razman340's Avatar
Car: 1985 Z28
i agree, it acts just like a vacuum line problem, that is the first thing i looked for, then checked all the plug wires....idles rough, poor performance. dunno. we're gonna check the cat, maybe go ahead and punch it out, and then check carb. carb was recently professionally rebuilt, and ran great, but maybe we got into some real bad gas?
Old May 25, 2011 | 01:50 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
It's not scientific but put your hand over the exhaust and if it feels like it's pushing gas out well it's probably not the cat. Especially if get someone to rev the engine and the exhaust flows well.
Old May 25, 2011 | 04:49 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
That's sounds scientific enough for me. My computer-controlled Qjet has run perfectly for 8 years after my brother rebuilt it, even the choke. It's only messed up twice, both times because dirt got in the intake: once when the carb to air cleaner gasket dried out and broke and again when we put headers on the car, leaving it without the air cleaner on for about two weeks.
Both times it ran rough, throttle stuck partially open then it would suddenly die. I sprayed the heck out of it about three times with carb cleaner, all around the throttle shafts and whatever air bleeds there are in the primaries, and it finally settled down without having to take the carb apart. All I can think is that it's sensitive to dirt, runs great for years but acts up bad when it eats some dirt--probably the same for bad gas.
Vintageracer
Jan 10, 2020 05:33 PM
chazman
Aug 28, 2018 03:25 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
