Straight back and dump?
Old Jun 30, 2011 | 08:49 AM
89camaro355's Avatar
Car: 89 camaro
Engine: 355 sbc
Transmission: th350
Axle/Gears: 4.56
Anyone ever run there pipes straight out of the headers then dump after the mufflers? Any clearence issues?
Old Jun 30, 2011 | 09:06 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Straight back and dump?
Nothing but clearance issues.
Old Jun 30, 2011 | 09:11 AM
Car: 89 camaro
Engine: 355 sbc
Transmission: th350
Axle/Gears: 4.56
Was afraid of that. My questions is what do I do lol. I have 3" longtubes
Old Jun 30, 2011 | 10:03 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Just have to route around everything like everyone else with longtubes does.
Old Jun 30, 2011 | 10:36 AM
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
I modified my transmission crossmember to allow dual 2.5" straight pipes to go underneath and tuck high. Never scrape.
Old Jun 30, 2011 | 10:56 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You don't have an automatic.
Old Jun 30, 2011 | 12:21 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Automatic is a pain to work around. You need at least an S type bend on each side else you'll run into the transmission/frame rails with Hooker long tubes. That will let the pipes drop down far enough to clear stuff hopefully. If you're using an aftermarket torque arm like the Spohn one that's just more stuff hanging down.
My 3" Y pipe is pretty well dinged in to fit. It's way to low in the front still. I've been thinking about how to change it. I might try notching the frame rails, welding plates in to box it off again, run the pipes through there, and connect the Y after the transmission.
Amillionoh7
May 24, 2020 08:01 AM
LittleFranks
Aug 20, 2015 03:55 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
