Which Headers/Y-pipe do you run?
Old Jul 4, 2011 | 04:34 PM
HighTechRedneck's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: Stock 9bolt posi
I have a few questions. I have looked at a ton of threads on here, and cannot make up my mind LOL.
Which Headers do you run? Which Y-pipe? Do you like them? Were there any clearance issues? Did the Y-pipe bolt right to the Cat?
I want to put headers on my car this summer, and was thinking Hooker 2055 with 3" Y-pipe. Does it bolt right up to the cat? Do I need to plug the holes in the headers since i took the Air system off? Is there a better header that will not have clearance issues w/ a 3" collector?
Lots of questions, anything will help, thanks!
I was thinking about the 2460-1hkr header with y pipe,
or HOK-2055-1HKR which comes with a y-pipe. I would need to block off the pipes for the AIR. It doesn't say on the 2055 how big the outlet on the exhaust tube is...
Old Jul 7, 2011 | 10:03 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Which Headers/Y-pipe do you run?
Look in here:
https://www.thirdgen.org/forums/exha...-8-shorty.html
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
