4" pipe that is a slip fit. What is the best exhaust clamp out there to seal this up?
Old Jul 12, 2011 | 06:59 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I have a 4" mufflex cat back, attached to their off road 3" Y-pipe. Both have been cut up exensively to fit other custom stuff done to my car. Anyways, I have one connection that is a slip in 4" connection. What is the absolute best clamp out there?
The ones that wrap around?
The old U-bolt style?
The wrap around and T-bolt style?
I have no idea, before this I had my pipes 100% welded up like an idiot, Oh the stupid things you do as a teenager!
Any insight would be great. Thanks.
Old Jul 12, 2011 | 07:36 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 4" pipe that is a slip fit. What is the best exhaust clamp out there to seal this
Not sure whats the best, but I used the wrap around band clamp styles with 2 bolts. Worked well for me.
my other car uses the old U-bolt style clamps and it does well.
Old Jul 12, 2011 | 09:08 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
the wrap around type (band) clamps tend to do a better job at sealing without deforming the pipe when correctly installed.
Old Jul 12, 2011 | 09:12 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
the old style u bolt permanently dents the exhaust pipe making it a pain in the **** to get apart at a later time
Old Jul 12, 2011 | 09:18 AM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
SS wrap around band clamps by far. Walker makes them and they are all I use. You can use them on butt-joints as well as lap-joints which is awesome.
U-bolts are garbage for garbage exhaust systems. They crush the pipe, sometimes so badly you cannot remove them from each other without cutting.
Single bolt band clamps are okay as well for slip fit with relief cuts. They just don't have the sealing capability like the longer 2 bolt band clamps do.
Old Jul 12, 2011 | 12:03 PM
Engine: LS3
Wow. Thanks for the super fast response. I will pick up a wrap around style. Thanks.
billybob6110
Sep 24, 2016 09:50 AM
MintWS6FORMULA
Oct 19, 2015 08:53 PM
86CamaroDan
Sep 29, 2015 10:08 PM
someone972
Aug 30, 2015 12:52 AM
downsouthboy
Aug 29, 2015 11:29 AM
