Dual Outlet Cat vs. True Duals
Old Aug 29, 2011 | 12:07 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 2.73 installing the 3.73 soon =D
I am looking into an engine that requires you run true dual exhaust on it to get the amount of power advertised, now I found a dual outlet cat that I am thinking I could run two pipes off of into mufflers, any input on whether true dual would be better or would this way work just as well? And also any ideas as to what it would sound like?
Thanks!
Old Aug 29, 2011 | 01:01 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Dual Outlet Cat vs. True Duals
the true dual requirement's a bit on the vague side; do they tell you what size is the requirement? most engines that end up in these cars are not going to be restricted by a 3" single catback and for the few exceptions, there are a couple 4" setups available as well. If you're trying to keep things simple, grab a decent set of shorties with a matching y-pipe, high flow cat, and any 3" catback you want. Unless you're pushing 400+ horsepower, you shouldn't be restricted with this kind of setup.
Old Aug 29, 2011 | 01:13 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
No required size listed, but I think I'll just go with a single 3" catback, I am thinking magnaflow 16829
Old Aug 29, 2011 | 03:23 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
ZEEYAA
Apr 16, 2023 08:29 PM
jrdturbo
Mar 31, 2016 02:58 PM
Night rider327
Oct 9, 2015 09:25 AM
91 SrS
Oct 7, 2015 04:32 PM
Night rider327
Sep 25, 2015 04:47 AM
