trouble installing edelbrock shorties
Old Sep 7, 2011 | 06:30 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 2.73 installing the 3.73 soon =D
I can't seem to find a way to get the driver's side header in from top or bottom and it is right against the steering column, haven't started the passenger side yet, recommendations?
Old Sep 7, 2011 | 08:13 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Re: trouble installing edelbrock shorties
Loosen the motor mount bolts, put a board under the oil pan and jack it up a hair, it will slide right in.
Old Sep 7, 2011 | 08:45 PM
EvilCartman's Avatar
Car: '82 Z28
Don't need to do that. Right in the instructions they say to slip the steering column apart at the bolt. I did both of mine from the top.
Old Sep 7, 2011 | 11:29 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Ditto to the above. 15mm wrench and that column will slide down and away from the engine. I recommend removing the sparkplugs too.
Old Sep 8, 2011 | 07:31 AM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
I bought mine used, so sadly no instructions, but I took that bolt out and it went right in, and the passenger side I took the fan temp out and it went in pretty easily, lost ALL of my coolant in the process, thanks to my slow hands lol, the steering colum is being a pain to put back together, but I'll figure it out, and Thanks for the responses to all of you!! =)
theshackle
Sep 17, 2020 08:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
fasteddi
Sep 2, 2015 10:29 AM
djmarch
Aug 19, 2015 12:07 PM
86IROC112
Aug 17, 2015 02:00 PM
