Single 3 Inch to Dual Converter Y Pipe on 88 L98 IROC.......has anyone done?
Car: 88 IROC-Z T-Top car with Bose
Engine: L98 5.7
Axle/Gears: 9 Bolt with 3.27's
Has anyone done this conversion? I tried to go from a stock dual cat y pipe to stock one 3 inch system on a 1992 B4C and it didn't fit using the dual cat manifolds. Just wanted to see what needs to modified before I tear into the car.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Single 3 Inch to Dual Converter Y Pipe on 88 L98 IROC.......has anyone done?
You're basically gonna need a custom pipe from the driver's side header to the other cat, and then y it back into the 3 inch catback. If your state's emissions laws allow it, I would convert to a single cat setup and call it a day. There is ZERO aftermarket support for the dual-cat setup.
Engine: 4++,350 & 305 CIs
here is the dual setup. Pricey 4 sure.
http://www.summitracing.com/parts/MPE-36479/?rtype=10
Engine: L98 5.7
Here's the one I was thinking of using.....definitely a little cheaper and I used one on a previous third gen.
http://m.summitracing.com/search?keyword=Catco%204153
Just not sure if it will fit. Didn't dual cat cars have a different hump in the floorpan?
Brinkkl2000
Aug 4, 2018 08:29 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
