What headers will work with my 5.7 with a T-5 Tranny
Old Oct 10, 2011 | 02:19 PM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
I'm going to upgrade to headers soon on my 85 Z28 and I need some help on brands and part numbers that will work with a 350 / T-5. All advice on recommendations will be greatly appreciated. Thanks!
Old Oct 14, 2011 | 01:39 PM
85 ZXX's Avatar
Re: What headers will work with my 5.7 with a T-5 Tranny
ttt
Old Oct 14, 2011 | 01:55 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
My summit brand work fine
Old Oct 14, 2011 | 02:23 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
The hooker 2055, dyno dons which both are on the classifieds right now for good prices
Old Oct 14, 2011 | 03:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's what I'm using on my 350 HO Deluxe (the following system is direct fit):
Hooker 2055's (Jeg's 520-2055). Catco high-flow converter (Summit CTO-9118). Hooker catback (Summit HOK-16823HKR).
JamesC
Old Oct 16, 2011 | 10:19 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Hedman 68460's here. Drivers side needed some massaging to clear the slave.
Old Oct 16, 2011 | 11:26 PM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Hooker 2210's cleared the slave no problem.
Old Oct 16, 2011 | 11:43 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
You didnt mention if you need the air tubes or not. Do you have a preference on long or short, and is your car lowered? I am running the Hooker 2460 and y-pipe and like there fitment (similar to the 2055 but without the air tubes and with standard flanges)
Old Oct 17, 2011 | 10:05 AM
85 ZXX's Avatar
Sorry, I forgot, no AIR tubes. I need the O2 bung on the drivers side header. I do have the car lowered with Eibach Pro springs and BMR A-arms.
Old Oct 17, 2011 | 10:27 AM
midias's Avatar
I use
http://www.summitracing.com/parts/SUM-G9005/
Headers on my 350 no air and o2 ports
http://www.summitracing.com/parts/BIG-11102YFLT/
This Y pipe
Old Oct 21, 2011 | 07:25 PM
85 ZXX's Avatar
Thanks for all the help and advice friends!
Frozer!!!
Jan 19, 2024 04:55 PM
jharrison5
Aug 19, 2015 05:53 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
drathaar907
Aug 6, 2015 04:20 PM
