2055 Paint?
Old Nov 19, 2011 | 07:36 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
2055 Paint?
I ordered the Hooker 2055 Y-Pipe and header set, and when I talked to a rep on the phone from hooker he stated that the black paint they come shipped with is ONLY for rust prevention during shelving/shipping and will burn off/rust once installed. However, EVERYWHERE I check online including hooker's website AND right on the receipt from the store I purchased them from states that the black coating is high temp paint.
I bought two cans of "aluminum" finish VHT ceramic header coating that I am going to spray the headers and Y-Pipe with but what I want to know is whether or not the black paint they come with will really burn off and take the VHT with it.
Sanding the paint off both headers AND the Y-Pipe is going to be alot of work so I want to know if I can just hose everything down with carb cleaner (The paint the headers come with does NOT seem to be affected by carb cleaner) for surface prep and then spray over top of it.
Can someone who has a set of these please chime in?
Old Nov 19, 2011 | 09:41 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 2055 Paint?
I'd just run the painted headers as is. After the paint rusts off I'd repaint them with high temp paint. I definitely wouldnt paint over the old paint.
Old Nov 19, 2011 | 10:04 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: 2055 Paint?
You should just take them to get sand blasted then repaint them.
Old Nov 19, 2011 | 10:12 PM
85_ZED28's Avatar
Car: '85 Z28
Re: 2055 Paint?
Agreed
Old Nov 20, 2011 | 07:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 2055 Paint?
My 2055's have been in place for a half dozen years or so and the paint hasn't fully burned off. I do, however, see a bit of rust here and there. That said, the car isn't really a daily driver, though it is driven frequently.
JamesC
Old Nov 20, 2011 | 05:07 PM
Car: 1985 Z28
Re: 2055 Paint?
The first header is hanging in my backyard right now. I sprayed the living crap out of it with aircraft stripper and carb cleaner and it ate the shipping paint off 100% with the added help of a wire brush. I then blasted the bulk off with a garden hose, then hit it with aircraft stripper again and another scrub followed by another blast with the garden hose.
Then blasted it with the air compressor to dry it out, then hung it in my backyard and sprayed down again with carb cleaner for surface prep. Then another air dry with the compressor and I'm currently between the first and second coats of paint.
Old Nov 28, 2011 | 02:00 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: 2055 Paint?
I hope that VHT paint works better for you then it did for me.
Old Nov 28, 2011 | 03:04 PM
Car: 1992 Camaro RS
Re: 2055 Paint?
ive seen it after a while of being applied... doesnt look fantastic but it looks better than bare rusty headers. Just my opinion, though.
Old Dec 5, 2011 | 06:59 PM
3rdgenmaro's Avatar
Car: 88 IROC
Re: 2055 Paint?
very true
Old Dec 14, 2011 | 03:44 PM
siduramaxde's Avatar
Car: 86 berlinetta
Engine: 383
Transmission: built 700r4
Axle/Gears: 3.42 zexel torsen
Re: 2055 Paint?
When I got my 2055's I cut the air tubes off and welded them shut. Then I sandblasted all the black paint off. I then used VHT silver paint and "baked" them in a BBQ grill for the time it says on the can. I put them on and they look same now as they did when I put them on 2 years ago.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
