what exhaust should i use?
I'm building an 84 camaro from the ground up and i've been doing alot of research on the project but one thing i'm now sure of yet is what would be the best exhaust to use on it. If it helps i'm using a 350 motor and a t56 trans.
Car: 1991 RS Camaro w/ Factory T-Tops
Engine: Built 355 ci SBC w/ Carb
Transmission: Borg Warner T-5
Axle/Gears: 4.10 with Posi-Trac
Re: what exhaust should i use?
Flowmaster has always worked well for me. Currently I've got a 1 in 2 out set up, but that's probably gonna get swapped to a true dual set up with my new engine.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Every once and a while I will go to YouTube and listen to a few exhaust videos.Some are drive bys and some are just idle with a rev. Any way just go to YouTube and punch in 'Camaro,and then the exhaust you want to listen to. I'm running a 3in. Flowmaster American Thunder 80 series with high-flow Magnaflow cat. Thats my preference.
david068513
Sep 18, 2015 10:36 AM
