new headers are one ...
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
i just installed a set of shorties yesterday on the marow . i'm deleteing the smog pump does anyone know what size belt i need to delete the smog pump but still leave the ac on . i brought it home with just the lines taking off the pump i don't want to leave it like this so i figured i could just take the pump off an put a shorter belt on justy not sure of what size belt .
Car: '90 RS
Engine: 305 TBI
Axle/Gears: 2.73 Open
Re: new headers are one ...
I believe you're supposed to measure the new length with a piece of string and subtract 1/2 an inch from that measurement. You may also have to change the way in which it is routed, I'm not sure
And off-topic but your Camaro looks sick the way it's stanced. I have the same wheels and tire size. How much did you lower it?
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Car: 85 sport coupe
Engine: 355 sbc
Axle/Gears: soon 4th gen 3.23 w/ Posi
ok so this is COMPLETELY off topic, but I absolutely LOVE your signature. I hope you don't mind if I post it on my facebook.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Engine: l98 tpi
Axle/Gears: 2.77
back on track tho for this thread since i changed the headers my car is missing real bad . i changed the plugs an had them gapped at 45 i went to get a set of new wires but they had to order them so they won't be in till wed. i reset my timing it was off a touch . i'm gonna check an make sure i don't have any wires resting on the header . that misses are random . any other ideas would be greatly appriciated .
Engine: l98 tpi
Axle/Gears: 2.77
ok i istalled new wires no car is hard to start when finally get it to idle the service engine light comes on . an it's idleing rich 10.0 a/f . wth ? any help would be nice here . thanks
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Are all of the sensors still hooked up? Knock sensor temp sensors and the O2 sensor.....O2 sensor if mounted in the y pipe should be replaced with a heated version. A search will provide the part number.
Engine: l98 tpi
Axle/Gears: 2.77
o2 senser is in the header just like the original , it's not giving any code but when the engine smooths out the light comes on . it's running so rich it messed up my wideband senser . is it possiable the narrow band is bad also compounding my problem ? i broke the senser on the passanger side under the manifold would the fan switch cause this condition ?
Engine: l98 tpi
Axle/Gears: 2.77
i replaced the stock 02 senser this morning the car is still starting hard ( sounds like it has a huge cam .which it doesn't ) still stumble for a few minutes then levels out aFTER SERVICE ENGINE LIGHT POPS ON . still not showing any codes .wtf ?
any help woulkd be appriciated .
Engine: l98 tpi
Axle/Gears: 2.77
all the sesers are hooked up , will a heated 02 senser stop the service engine light from coming on an fix the starting problems ?
Car: '88 Trans Am GTA
O2 sensors are not used untill the engine is warm. The hard starting issue is most likely somewhere else. Heated sensors are usually recommented with headers because they disipate too much heat to warm it up naturaly.
Engine: l98 tpi
Axle/Gears: 2.77
i got it to show a code today 21 so i've figured out my problem . thanks for the ideas .
Engine: l98 tpi
Axle/Gears: 2.77
ok today i checked my volts engine off key on 5.06 . started engine after idle leveled out at idle 0.42 . but still have the extremely rich start with rough idle then after a min. or so it levels out .the motors all stock except free flow k&n filter with the filter top no cat an hshorty headers . i'm wondering if a heated 02 will fix this or what else could it be ? i'm planning on getting the ebl flash next month . i can live with the rich start for now since it drives fine after it settles in if it wiull last until i get the new computer . help
this happens with the motor hot or cold ...
Engine: 4++,350 & 305 CIs
A factory service manual from Helm will do wonders. We can only guess.
Engine: l98 tpi
Axle/Gears: 2.77
well new up date , started really rich took longer to level out now the idle is a mess up an down an it's stalling sometimes after i get to a stop sign or light .
BumpaD82
Feb 26, 2016 02:57 PM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
