Good budget headers?
Old Jan 8, 2012 | 11:23 PM
MadCelt's Avatar
OK.... I have a short thread in Engine Swap. Ordered my L31 crate, ordering the StealthRam and other tidbits this week.
Not sure what I want to do about the exaust. I of course want to replace the stock manifolds (was a 305 TPI). Already deleted the AIR, tubes and all, so no issue there. I'm wanting an affordable set of headers and Y to fit. I already have a high flow Cat on order, and will run an exhaust kit backk from that. Suggestions? I have heard fit issues with Hedman, etc various troubles with various headers. I won't be going nuts on HP with this motor, just want enough flow to let the engine do it's thing with the 'stock' cam for now, since changing that gets into machining the vortec heads for more than what, .050 lift and changing springs and all.
So I'm not looking to pull 400+ hp, just enough that the exhaust isn't anemic for the 'stock' L31.
Suggestions? Anyone? My primary concern here is ease of fit and getting it all together without having to bend-cut-weld-grind.
Old Jan 8, 2012 | 11:40 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: Good budget headers?
Dyno Don's. Search it.
Old Jan 9, 2012 | 07:16 AM
MadCelt's Avatar
Ahhh thank you!!! Searched here and on Google, seems everyone who has gotten them loves them. It's pretty much gonna be tip-top of what I wanted to spend, but hey, quality is quality. I'll be PM'ing him in a couple weeks when I'm ready to order. Thanks!
Old Jan 9, 2012 | 04:58 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
why are you running a cat if you deleted the air system?all the stuff has to be on there to be 'legal'.
Old Jan 9, 2012 | 06:24 PM
MadCelt's Avatar
Smog police!
FL doesn't smog check. Nobody is going to be poking under my hood. Even if they did the tailpipe probe, it wouldn't matter. The AIR system simply aids in heating the cat from 'cold' until it's up to temp, to enable it to convert CO into CO2 quicker. Once the vehicle has been running for a bit, the Cat will function fine on it's own. Nobody I know that lives in a smog state and has removed the AIR has ever failed due to that alone, except in CA, where they will open the hood and do a looksee. So, unless the Fed decides to start kicking in garage doors, I'm not terribly concerned.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wvcamaro
Sep 4, 2015 08:38 PM
camaro71633
Sep 1, 2015 10:24 AM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
mustangman65_79
Aug 7, 2015 09:55 PM
