oxygen sensor questions
Old Jan 11, 2012 | 08:32 AM
Jakes92RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1L
I need to know how many sensors are on a 1992 3.1 RS Camaro and where they are located. I heard there is only one locates on the driver side exhaust manifold. Oh and what size wrench should I use to get an exact fit? I heard the make a special socket for it, but I'd rather try it out with a wrench first. Thanks
Old Jan 11, 2012 | 10:28 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: oxygen sensor questions
a stuck oxygen sensor is going to fight you enough as-is, don't use a wrench and risk rounding it out. any advance auto or autozone has the correct sensor sockets as part of their loaner tool program. these cars only use one sensor on them, should see it sticking out toward the bottom of the manifold.
Old Jan 11, 2012 | 11:05 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Should be pointing inboard just after the Y pipe.
Old Jan 11, 2012 | 04:15 PM
Jakes92RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1L
How much does it cost to be loaned a socket?
Old Jan 11, 2012 | 05:20 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
as i remember it you leave a deposit and get it all back when you return the tool.
Old Jan 11, 2012 | 06:09 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I couldn't find my socket so used a wrench. It wasn't seized so came out fairly easily. You could try a wrench but if doesn't give way with moderate force buy/borrow the socket.
Old Jan 12, 2012 | 07:04 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
IIRC, advance auto loans out the set of 3 or 4 for about $30, but you get all the money back when you return them
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beast94
Aug 20, 2015 06:44 AM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
