3" y pipe? who makes it??
Old Jan 27, 2012 | 09:41 PM
tjtaylor's Avatar
Car: 1991 Camaro RS ttops
Engine: 00 383
Transmission: t-5
Axle/Gears: moser 9" 3.50
im gathering parts for my camaro for the spring time, just picked up my magnaflow catback exhaust 16829 from summit. i have hooker shorty headers 2460s. i need an aftermarket y pipe that will fit those headers and have a true 3 inch pipe to the converter. Im not looking for 3" collectors and 2.5" pipe, unless you folks can tell me that the 2.5 would be suffiecent enough for my 383
Old Jan 28, 2012 | 01:12 PM
85_ZED28's Avatar
Car: '85 Z28
Re: 3" y pipe? who makes it??
I don't believe such a y pipe exists for those headers. You'd have to modify the one that goes with the 2460s or get something custom made.
Old Jan 28, 2012 | 06:33 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
What cam, comp, and heads are you running??
Old Jan 28, 2012 | 11:34 PM
tjtaylor's Avatar
Engine: 00 383
Transmission: t-5
comp cam 288 procomp 200cc heads atm and 9.7 static and i guess like 7,5ish dynamic
Old Feb 2, 2012 | 06:28 PM
mstng5pt0klrz28's Avatar
Car: 1985 Z28
Hooker have the super comp shortys and y pipe combo (PN 2055) which has the 3" y pipe...
Old Feb 2, 2012 | 10:28 PM
tjtaylor's Avatar
Engine: 00 383
Transmission: t-5
is it 3inch all the way ? or just a 3 inch collector to a 2.5 inch pipe then to a 3 again? ever used this set up?
Old Feb 3, 2012 | 06:47 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The sticky at the top of the page should provide an interesting read. The following is a direct-fit 3" system:
Hooker 2055's (Jeg's 520-2055). Catco high-flow converter (Summit CTO-9118). Hooker catback (Summit HOK-16823HKR).
JamesC
Old Feb 3, 2012 | 04:45 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Flowmaster makes one. Look in the Summit book. Dual 2.5 into 3in pipe. $39.95 Part# FLO-Y250300. http://www.summitracing.com/search/?...-y250300&dds=1
Old Apr 26, 2012 | 04:06 PM
Guest
Guest
Posts: n/a
I dont know much about your headers and the flow. But if you use a 2.50 Y with a dual 2.50 or 3" convertor out to your Magna Flow 16829 with your 383ci that will be fine. Im Ca carb and shops only have the 2.25 or a 3" and I have a 2.50 Y so Im guessing they expand my 2.50 to fit the 3" I hope. I just dont know the measurements of the expand and dual fitment. I posted 90 Dual magna flow convertors 2.50 Y fitment?? what needs done.. One shop with the best price wants to install 2.25 Ca carb cats and Im like Nah. And they trip out like there not suppost to use the 3" and they can get in trouble with the smog station.. Sounds like B.S to me.. I want to know what needs done to go with the 3".. I had a dyno jet tuning Dfi session on wide band an dfi map tuning 389rwhp an 442rwtq.. And the timing wasnt even finished.. 1/8th mile time with custom tune ran faster with the ecu. So I sold the Dfi Gen 6 plug n Play..Takes to old of lap tops to run so I got out of it while I could..
Old Apr 29, 2012 | 02:19 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Maybe this one:
http://www.summitracing.com/parts/HOK-16767HKR/
Old Apr 29, 2012 | 06:17 PM
tjtaylor's Avatar
Engine: 00 383
Transmission: t-5
i actually went to the tallmadge store recently and looked at that part # and honeslty was not impressed with the part. its is alll bare pipe and the transitions from 3 inch collector to 2.5 inch pipe were horrible. i could weld bettter than that and i dont weld. hedman makes the same kit for like 125 and its much nicer quality and its painted too
Old Sep 16, 2012 | 04:31 PM
face215's Avatar
Car: 89' GTA
Engine: L98 with tpi to carb swap
Axle/Gears: stock
Im sick of all the b/s !!!! Someone make a gdam 3" y pipe already!!!
Old Sep 17, 2012 | 06:51 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
make your own...3" is tough to fit in the stock location.
Old Sep 27, 2012 | 01:38 PM
mmorley1024's Avatar
Car: 1985 irocz
Engine: 305 the l69 was removed years ago.
Transmission: t-5
Axle/Gears: 3.73 peg leg
yes, i just picked up a parts car with emission headers mid length and it has to be 3 inch all the way out with no cat into one 40 series flow and single out all 3 inch, but the y pipe where is crosses from the left side is about an inch below the crossmember so it has a dent in it from bottoming out but i haven't checked on what headers they are, i am thinking about putting them on my 85 iroc seeing i need a set of headers anyways, just run the 2.5 so you don't have clearance issues.
87iroctheo
Dec 4, 2016 11:47 AM
hectre13
Sep 8, 2015 03:38 PM
Warlocksirix
Sep 3, 2015 12:26 PM
lt1z350
Aug 28, 2015 05:57 AM
TheExaminer
Aug 26, 2015 04:59 PM
