Headers for H-Pipe Setup?
Old Feb 20, 2012 | 04:50 PM
Guest
Guest
Posts: n/a
What would be the best headers for an H pipe setup on a 1992 L98 Camaro that would't break the bank aka cheap?
Old Feb 20, 2012 | 11:32 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Headers for H-Pipe Setup?
If you're okay with giving up any semblance of emissions legal and decent ground clearance, the cheapest way is Hedman long tubes 68460 (something like that) and a couple of Hedman header (s-extensions I think they cal them) and a bunch of 2.5 inch pipe and a couple of summit welded mufflers.
You could probably do it for around $350ish before any sort of labor. Probably one of hte easiest setups to build and the ground clearance isnt super terrible, it's just regular bad.
https://www.thirdgen.org/forums/post...77-post11.html
Sounded really nice...
Also, use all-metal locknuts for the collectors. They dont use a nylon ring, they use a warped thread or something... locks itself to the bolt so they wont come loose all the time. I had a constant problem with losing header collector bolts til mw66nova turned me onto that solution.
Your car may run a little funny after this. You wont get any huge gains until you retune the car, but it's not 100 percent necessary.
I would recommend you run shorties and a factory-style catback in general, but if you're dead set on this, that's the best way to do it.
Old Feb 21, 2012 | 07:02 PM
Guest
Guest
Posts: n/a
Why are shorties preferred? And how do i install two headers with one pipe going into the engine from the exhaust?
Old Feb 21, 2012 | 11:08 PM
Car: 1992 Camaro RS
Shorties are preferred because they run the exhaust from both sides of the engine through the stock location. The stock routing allows for decent ground clearance.
Bubbajones_ya
Jul 6, 2024 08:32 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Accerrito22
Sep 5, 2015 09:34 PM
