Muffler Clearance / mounting angle?
Old Feb 22, 2012 | 07:15 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
So I am in the process of setting up my magnaflow 3" catback and curious as to how much ground clearance I should have under the muffler? Also what angle are you guys mounting it at? Parallel with the ground or on a angle?
Old Feb 24, 2012 | 09:51 AM
insomniac's Avatar
Engine: 5.7 L98
Re: Muffler Clearance / mounting angle?
ttt
Old Feb 24, 2012 | 04:32 PM
Ajaxzem's Avatar
Car: 85 Trans AM
Engine: 305 LG4
Axle/Gears: 3.08
Mine is mounted at an angle just like the stock muffler was. You can only really tuck it up so far til you either hit the heatshield or your tail pipe on the drivers side will hit the inlet pipe. I put everything together and left it loose until i adjusted everything right where i wanted it, then i started tightening up clamps one by one. Then i went back a day od two later and made a few minor adjustments.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
