Need straight forward experienced input.
Old Feb 24, 2012 | 08:06 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Axle/Gears: soon 4th gen 3.23 w/ Posi
ok, so to get some crap out of the way,
DO NOT:
tell me to search/look up this info
give me your opinion if you've never done this before
THANKS!
Now, what I want to know, I bought a set of hedman 68460 headers from a member on here. (also came with the true duels and flowmasters on the end that dump before the rear.) I asked him how he put them on and he said that he had the engine out of the car and dropped it down with someone holding the headers in place. I honestly don't plan on doing that, so I've looked into (on here) how others did it and how hard it would be. I asked the member if he had any ideas how I should do it and he said I would probably have to pull the starter and jack up each side then I'd probably be able to slide them up from the bottom. How close to feasible is this? will I run into any other issues? I have a 85 SC with completely stock engine except for Chevrolet valve covers and edelbrock intake. Also I sand blasted them and was going to hi-temp spray them but don't have an industrial oven, can I just do it in my house oven?
Any and ALL info will be appreciated. Also if I have any more Q's (which I'm sure I will) I will be sure to post
Old Feb 24, 2012 | 08:09 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Re: Need straight forward experienced input.
oh yea, I need help finding the bolts to attach the headers to the block and to connect to collector. any references?
Old Feb 24, 2012 | 08:25 PM
Keegan84's Avatar
Car: 84 trans am
Engine: 350 bored .020 over
Transmission: TH350 w/ stage 2 B&M shift kit
Axle/Gears: 9 bolt/3.27
You can use the high temp paint and cook them on the car, like the instructions suggest on the back of the can. I actually have the same headers, but waiting for warm weather to put them on. When you get it all hooked up pics and info would be awesome.
Old Feb 24, 2012 | 09:48 PM
tubbytownsend13's Avatar
Car: 87 iroc
Engine: mostly stock 5.7
Transmission: jasper stage 2 700r4
Axle/Gears: stock
use the stage 8 locking header fasteners go on summit and find them and the bolts. easiest way is to undo the motor mounts and jack it up a hair...still a pain though..hopefully he dented the driver side a little so it clears the k member
Old Feb 25, 2012 | 10:10 AM
355sleeper's Avatar
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
i agree i use these bolts and havent had one back out yet...
i also have these headers and i dropped them in with the motor
Old Feb 25, 2012 | 10:15 AM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
yea, he has already dented them, thanks for the help so far, keep it up!
Old Feb 27, 2012 | 11:15 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
DO NOT:
THANKS!
a word of advice,wait till your mate is out!! before using their oven.there is some trick bolt kits that have a lock that fits over the bolt head ,held on by a "c" clip.it prevents the chore of constantly re tightening the bolts.i forgot who makes them but they work well
cheesehomer
Dec 31, 2015 08:48 AM
BrianI
Oct 3, 2015 12:57 PM
mfp189
Sep 27, 2015 09:25 AM
FED 387
Sep 16, 2015 12:18 PM
89 formula TPI
Sep 8, 2015 08:00 PM
