Would you reccomend these Headers..??
Subscribe
Mar 31, 2012 | 02:15 AM
Would these headers be a good fit for my 1984 Z28 305 engine...
https://www.thirdgen.org/forums/exha...ml#post5228837
and about how much does it cost for a mechanic to intall..., and what exactly do heades do?thanks!
Reply 0
Mar 31, 2012 | 03:02 AM
Re: Would you reccomend these Headers..??
What headers, your other thread is talking about flowmaster mufflers? I have flowtech headers (headers and y-pipe are about $220 for both) Great improvement in sound, but I also have 3" flowmaster exhaust.
Reply 0
Mar 31, 2012 | 04:34 AM
I have Hooker super comp ceramic LT's on mine they fit great. Only downfall is having to pull the motor for install even with smooth firewall. They wrap the lower CA's tight. I'm completely satisfied.
Reply 0
Mar 31, 2012 | 05:08 AM
Headers flow better than the log style cast iron manifolds. Because each cylinder has its own exhaust port. Further headers can offer a small scavaging effect to help pull out burnt gases for better efficiency. Side effect, good or bad is a slightly noisier exhaust note and higher under hood temps, but some coats help negate this. Generally speaking a good upgrade.
Reply 0
Mar 31, 2012 | 05:41 PM
Do you guys recommend any headers that are good prices but then again I dont wanna spend $1000's of dollars. I just need something moderate that will give me good HP gains and economy. Can you supply a link to them if you can...thanks!
Reply 0
Apr 1, 2012 | 04:07 AM
Read the sticky up top:
https://www.thirdgen.org/forums/exha...ion-chart.html
Old thread but info is still relevant, have to research yourself for current prices.
Reply 0
Subscribe
