building my own headers
maybe this is a rookie question but i've been looking at building my own headers and was wondering what this tool would be called cause i can't seem to find it
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: building my own headers
I just came across this the other day myself, in my online wanderings:
http://www.stainlessheaders.com/headerfabrication
Watch the videos at the bottom of the page.
This isn't a tool, it's a mockup of the headers in plumbing pvc piping and bends. Pretty clever idea I thought.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
There isn't 'one' to buy. Its a one-off mock-up assembly of separate plumbing bits from Home Depot or wherever - elbows and pipe pieces cut to length. It doesn't have articulated joints.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I thought some of the custom header manufactures would send you that as a kit in order to mock it up with the engine in the chassis?
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Actually I take it back - in the second video from the vendor above, it's stated that they have articulated joints available for hire. Seems you can use these in conjunction with the plumbing stuff if you wish.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
There is a bendable foam setup available, have seen it on TV and in HotRod mag, cannot remember the mfr.....
