Smog pump
Smog pump
Hello. I drive a 85 iroc z with a 305 tpi. So I was wondering, i was doing research on what a smog pump does and I think I know now. It takes some of the unburned exhaust out from the headers and puts it back into your intake to reduce emmisions? Oh and it runs off a pulley. So if this is all true I think I want to remove mine for sure! It seems like mine runs off of its own individual belt. I was wondering if, for the moment, I could just remove the belt and see the difference in power? I looked up a lot of threads on this though and people need to reroute their belts? I'm still kind of new at this but I don't think I need to reroute mine so if someone can clear that up for me it would be great!
Transmission: 4L80E/4L80E
You're mixing EGR and A.I.R. (aka, "smog pump").
EGR is Exhaust Gas Recirculation. Under certain conditions, it mixes a small amount of exhaust gases back into the intake air/fuel stream to cool the combustion temperatures to reduce the production of nitrogen oxygen compounds, which are air pollutants.
Air Injection Reaction is the "smog pump". It puts some air into the exhaust to help promote the burning of unburnt fuel while the engine is warming up, and into the cat to improve the efficiency of the catalyst.
Re: Smog pump
Car: 87 GTA
Re: Smog pump
The .001 hp you'll gain by removing the pump, won't be worth no longer passing come inspections.
You WILL NOT feel ANY increase in horsepower. What you WILL get is a car that no longer passes at inspection time & a heft fine for tampering with Federal Emissiojns equipment.
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: Smog pump
What inspections?
The main reason to ditch it is when it breaks and locks up. A smaller belt is cheaper than a new pump. Plus the weight savings is nice.
Car: 87 GTA
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Open 2.73
Re: Smog pump
Well I removed mine to clear up some of the clutter in the engine, that and my headers werent emissions headers. Around here I know they dont do emissions test so I'm pretty safe, but if they do emissions tests in your area I would just leave it on. If you do end up taking it off though, make sure to keep it just in case you ever have to have the thing tested. If you do desire though, all u havta do is take the belt off and then the pump itself and your set.
I know its a little off topic but it seems like ur lookin to add a little more power, u should look into putting an underdrive pulley on it if you already havent.
Car: 1991 Firebird
Car: 87 GTA
Re: Smog pump
Not in awhile, off the floor in my car port, where it is currently laying.
Maybe I'll go weigh it for you. I doubt it would even hit 5 lbs. Even IF something was 10lbs, losing 10lbs alone ain't gonna do anything to make a car faster. It certainly putting enough drag on an engine to ever be of any noticeable drag.
Car: 87 GTA
Re: Smog pump
Smog pump + the main mount bracket + the support rod + all the bolts...........
13 lbs
My GTA sure felt like a ROCKET after I took mine off last year
13 lbs
Car: 1991 Firebird
Re: Smog pump
13 pounds IS nothing. But...
"If you can't remove a pound from one place, remove 1 ounce from 16 places."
A/C delete by itself doesn't matter.
Rear seat delete by itself doesn't matter.
Fiberglass hood by itself doesn't matter.
Aluminum driveshaft by itself doesn't matter.
But they add up. 120 pounds matters.
Car: 89 Camaro
Engine: 2.8 V6
Axle/Gears: 3.42 open
Re: Smog pump
i was racing my iroc with a 454 and a muncie 4 speed last year and i was running 11.59s consistently on the bottle and i got out to take a **** and i got back in and was running 10.32s. a little weight goes a long way.
Car: 92 Camaro RS
Engine: 305 TBI
Re: Smog pump
Re: Smog pump
Well as much as I understand weight reduction can help a car go faster, I was actually doing it just for the pulley delete. You guys don't think I'll get much horsepower out of it? I mean the motor is still stock I'm working on getting the car running in good shape first before I do anything major. I just thought that if you get rid of a pulley obviously less strain on the engine. What do you guys think my hp increase will be?
Car: 92 Camaro RS
Engine: 305 TBI
Re: Smog pump
Well if I would have to say anything, maybe 1-2 horsepower. It does take drag off the engine, so their will be an increase, just nothing that you will be able to feel.
Its more or less worth it more for the fact that if you plan to do any mods later down the road, like headers, it makes it alot easier because you dont have to fight with all the smog equipment.
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Smog pump
when i removed mine,shortly after getting the car in
1990,no HP increase was noticed but the dorky buzz
of the smog pump at high RPM was gone
