Long tube Header Help
Old May 14, 2012 | 07:34 PM
octkkk's Avatar
Engine: 305, 400
Transmission: T5, 4spd
Axle/Gears: 4:10, 3:73
I just got some Headman Long tube headers and with my car finally running they sound great. But how am i supposed to put an exhaust on after that. Every muffler shop says its to low to run a y pipe under the trans. And i also have two cut outs i want to install. What do I do.
Old May 14, 2012 | 08:46 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Re: Long tube Header Help
Find a shop that will do it. I have the same headers and I have a y pipe and have plenty of clearance. A good shop will be able to do it.
Old May 14, 2012 | 09:09 PM
octkkk's Avatar
Engine: 305, 400
do you have a pic of where the y pipe is located? is it under the trans
Old May 14, 2012 | 10:17 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
You have a T5 so the collector should be right in the way of your slave cylinder. You'll have to have something custom done to get around the slave cylinder. You can cut off the collector and extend it, and then dimple the extension to clear it - that's probably the most elegant solution I've seen. Beyond that you'll be able to run the exhaust above the trans crossmember if you're clever and have good motor mounts that will allow for the tight clearances that will result, but most likely you'll be at the whims of some exhaust shop and they'll just run it under the trans - much easier that way, but way worse ground clearance. And that's IF you find a shop to run you a custom exhaust. A factory style catback is no longer an option.
Old May 15, 2012 | 12:43 AM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
There is a Sticky above this Thread by Traxion
https://www.thirdgen.org/forums/exha...oker-long.html
There are many pictures there...
It's really not that difficult... the shop just has to take their time.
I had a shop build me one and it was pure crap... Power robbing Pinched bends everywhere!
So I built my own Y-pipe... All Mandrel bent 3" Y-Pipe. Into a 3" Flowmaster Catback system.
https://www.thirdgen.org/forums/exha...y-new-3-a.html
Here's Skinny Z's Thread (Good Pics)
https://www.thirdgen.org/forums/exha...-3-single.html
There you go... Enjoy!
Old May 16, 2012 | 06:38 PM
octkkk's Avatar
Engine: 305, 400
thanks for the help
Old May 29, 2012 | 05:00 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Look up in the "Dual exhaust picture" thread in the sticky section. Some awsome examples. Just print some out and say "just like that"...and watch to see if they're skills are up to the task.
morrow
Jan 13, 2024 12:29 PM
italiano67
Dec 11, 2016 09:21 AM
92projectcamaro
Jan 18, 2016 08:00 AM
formula_novice
Sep 5, 2015 03:58 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
