LT Headers to 3" single exhaust
Old May 22, 2008 | 11:23 PM
skinny z's Avatar
For what it's worth, here's the progress so far.
If there are are any comments, I'll post additional pics.
Old May 23, 2008 | 12:39 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: LT Headers to 3" single exhaust
Looks super clean. Who makes that Y peice?
Old May 23, 2008 | 11:03 PM
skinny z's Avatar
It's a Magnaflow 2 x 2.5" into single 3" merge collector.
I've got a part number I'll post later.
Here's a look at the finished product.
Old May 30, 2008 | 09:38 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
wow looks better than mine...i bet alot cheaper too....darn exhaust guys charge too much
Old May 30, 2008 | 10:05 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
It's a work of art man....... plain and simple !!!!!!!! I mean that!!!!
Holy smokes man!!!!
How did you build that !!!!
Mines crap in comparison..........(there's pictures out there but I'm too embarassed to repost them.....)
I need to learn how to weld!!!!! You didn't do anything with your transmission crossmember did you ??? How much clearance do you have???
Looks Great!!!!!!!
Old May 31, 2008 | 10:45 AM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Bump !!!!!
Everybody should be looking at this thing!!!!
Old Jun 2, 2008 | 08:51 AM
skinny z's Avatar
I can't take the credit for this work.
The guys name is Tom Britton. He runs a business called Altered Images. It used to be the installation division of Performance Improvements (like Jegs or Summit)
He's a master. Plain and simple. Does lots of Nostalgia gassers. Full tube chassis', suspension, etc.
I've got a couple more pics.
Attached Thumbnails LT Headers to 3" single exhaust-100_1847.jpg   LT Headers to 3" single exhaust-100_1844.jpg
Old Jun 2, 2008 | 09:11 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
Got any pics with it installed that show ground clearance?
Old Jun 2, 2008 | 11:14 AM
Car: 92 Camaro
Axle/Gears: S60 373
aha found the part # MPE-10778 from summit. It looks like he used two hedman extension S bends on there is that correct?
Old Jun 2, 2008 | 11:51 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
he probably just used mandrel bent pieces.
looks great, btw. A flowmaster merge pipe has a little smoother transition, just as a point of reference if anyone else is wanting to do this.
http://www.jegs.com/i/Flowmaster/389/Y250300/10002/-1
Old Jun 2, 2008 | 05:01 PM
skinny z's Avatar
It's all mandrel bends. I picked up 4 Y-J stainless steel bends from Vibrant.
It's all slice and dice after that.
Old Jun 2, 2008 | 05:07 PM
skinny z's Avatar
Everything is fabbed from 4 different Y-J stainless mandrel shapes. Here's a shot of the tacked together piece ready for purged TIG welding.
Old Jun 2, 2008 | 05:10 PM
skinny z's Avatar
It's back on the hoist for some additional work.
I'll post some ground clearence pics when it's finished.
Old Jun 3, 2008 | 03:35 PM
ino's Avatar
ino
Car: 87 firebird
That is a very nice setup you have there.
Old Jun 3, 2008 | 05:37 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
very nice, i'll post up pics of my setup soon as i get it done but its pretty similar to yours. BUT i'm using spohn crossmember so i ran the pipes abit wider around that, and i'm using regular aluminized pipe and mig welded and its not the prettiest welds but it works
Old Jun 3, 2008 | 09:53 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Do you have any pictures of that Spohn crossmember? I was thinking of fabricating my own by cutting and channeling an original.
Old Jun 3, 2008 | 10:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
not yet, but i didnt cut up my crossmember and so far clearance looks pretty good. I'll have pics up later on when i get a chance to finish the build
Old Jun 3, 2008 | 10:40 PM
skinny z's Avatar
Here are a few shots of a modified stock crossmember.
Attached Thumbnails LT Headers to 3" single exhaust-100_1897.jpg   LT Headers to 3" single exhaust-100_1898.jpg
Old Jun 3, 2008 | 10:46 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
definitely interested in these
Old Jun 4, 2008 | 07:29 PM
skinny z's Avatar
Here's a couple.
My driveway has quite a bit of crown to it so there's even more clearence.
Doesn't give me a problem at all even fully loaded with a couple of passengers , two sets of golf clubs and 100 lbs in car parts. ( I was shopping at Jeg's and Summit)
Attached Thumbnails LT Headers to 3" single exhaust-100_1951.jpg   LT Headers to 3" single exhaust-100_1948.jpg
Old Jun 4, 2008 | 09:26 PM
Car: 92 Camaro
Axle/Gears: S60 373
not too shabby
Old Jun 4, 2008 | 10:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
thats what i'm hoping to gain out of mine that be plenty of clearance
Old Jun 4, 2008 | 10:28 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Originally Posted by skinny z
Here's a couple.
Does give me a problem at all even fully loaded with a couple of passengers , two sets of golf clubs and 100 lbs in car parts. ( I was shopping at Jeg's and Summit)
that looks pretty good. ive got the spohn crossmember and the local muffler shop did a so-so job on it, looking forward to pics from Orr89RocZ; i really dont want to cut up that crossmember.
good job; good ground clearance. those are 2.5 in pipes right?
Old Jun 5, 2008 | 12:41 AM
skinny z's Avatar
I can see that it's more difficult with the Spohn crossmember. I would probably fab one myself based on Spohn's pattern although I'd make room for collector extentions and duals.
I will say one thing for sure. There's no comparison between a run of the mill short tube header system (this dosren't include Dyno Don's headers) and a LT header with a decently designed 2 into 1. It's not duals (yet) but the difference is amazing.
I intend to pursue the resonator box however for now, I'm looking for my first 12 second time slip.
Old Jun 5, 2008 | 12:50 AM
skinny z's Avatar
Yes. I reduced the collector to 2.5" at the header. With less than 400 hp , 2 x 2.5" has more than enough capacity. I also like the tuning range of the smaller collector.
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
Accerrito22
Sep 5, 2015 09:34 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
