Magnaflow 49 state cat converter on a California Car?
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
I recently purchased a 1984 Recaro T/A from California, brought it home to Illinois and I was going to install a 49 state cat converter from Magnaflow. Will this throw engine codes since the car's computer is set up to sense CA emission parameters? If so, can the computer be re-programmed? How?
Chuck
Chuck
Car: 91 Camaro RS
Engine: 355 Vortec
Re: Magnaflow 49 state cat converter on a California Car?
No after cat O2 sensors on these car like the newer OBD2 systems. So, the the cat is not monitored. Should not cause any codes.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I've never seen any difference in computer programming between a California thirdgen and a federal thirdgen. The carbureted early thirdgens might be different, but the fuel injected ones are all the same. I think the CA vs Federal emissions thing was in the 70's, and by the 80's, the engines were the same.
That said, no you will not have any problems changing the cat on your car. Thank you for doing the responsible thing and keeping a catalytic converter on your car.
Thanks for the heads up! Looking forward to getting that installed now that there should be no issues!
Chuck
Chuck
3rdgenparts
Aug 6, 2015 09:03 AM
