rough idle
Car: 1991 Pontiac Firebird Formula
Engine: V-8 305
Transmission: Unknown
Axle/Gears: Unknown
rough idle
So a few months ago i got this car by a seller off the street.Thought it was a good deal but now im finding out it wasnt worth it. The car had been modified,the Catalyltic converter was taken out and replaced by a straight pipe.And a flowmaster exhaust was put in. Due to this my cars giving errors to the engine that im not getting oxygen. its running really rough and ocassionally stalls until i reach an engine temp of 150 degrees. Is there any kits or ways to solve this issue. Was told the engine guessing how much fuel its getting cause there is no sensors to tell it.
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: rough idle
No cat and a flowmaster exhaust is not going to cause a rough idle. What exactly are the SES codes it's throwing?
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: rough idle
yeah you have another problem. Take a paper clip and jump the two upper right pins on the data connector, the SES light will then flash you the codes through the dash. im sure there is a explicit write up somewhere
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: rough idle
